Steering Wheel Vibration at Highway Speed
Old Aug 7, 2016 | 12:03 PM
LTBALTBMX's Avatar
My steering wheel is shaking at highway speeds. The vibration peaks at around 100 km/h and disappears above or below this speed.
I have new continental extreme contact DWS06 tires that were installed and balanced last week.
The front hubs have less than 10,000 kms on them.
The driver side front rotor was cracked and replaced last week. There is no pulsation in the pedal during braking, so I think the other rotor is fine. There is nothing visually wrong with it either.
What could this be?
Old Aug 7, 2016 | 06:13 PM
cluelessk's Avatar
Probably the balance of her tires.
Could be a bent wheel that from the back to the front.
Old Aug 7, 2016 | 09:39 PM
63 Nova SS's Avatar
Check your front tire balance. If you are on aftermarket wheels make sure your centering ring on the wheels to fit the wheel hub, is installed.
Old Aug 8, 2016 | 08:13 AM
LTBALTBMX's Avatar
I swapped the front and rear wheels. The vibration is still present. I noticed that the vibration is more profound under light throttle vs. coasting through the resonance speed.
I'm on stock lnf wheels.
Old Aug 8, 2016 | 10:25 AM
I'm going to lean towards axle if it's more profound under acceleration
Old Aug 8, 2016 | 12:11 PM
Northindy's Avatar
I have the same tires. My first new set pulled to the right. They replaced them and the pull went away. May not be your same problem, but at least one tire shop mentioned to me that they have seen issues with new Continentals. I did not have a vibration with mine.
Old Aug 8, 2016 | 12:18 PM
CudaJoe's Avatar
vibration could be tire wheel balance. Most shops balance to 60 mph. If the vibration is strongly present at highway speeds but not lower speeds than that might be it.
Old Aug 8, 2016 | 09:05 PM
LTBALTBMX's Avatar
Any idea how to isolate for this issue? I looked at my axles (not the cross shaft) and didn't notice any missing weights, or any weights for that matter.
Crap... Did you warranty through continental?
GreenStang
Jun 16, 2016 12:54 PM
ForsakenOutlaw57
Jun 7, 2016 08:21 PM
cavfiredesire
May 25, 2016 09:33 AM
ItalianJoe1
May 19, 2016 04:20 PM
Tehmaster
May 18, 2016 11:19 AM
