Synapse Motorsport Cobalt Development
Old Jun 18, 2008 | 08:27 AM
  #51
craig's Avatar
My lnf results are comparable to that. Link bellow.
Old Jun 18, 2008 | 09:26 AM
  #52
QuikSilverSS's Avatar
Thats pretty impressive, i knew when i took one for a drive that it would take a bolt on tage 2 to tie one! Wait til the aftermarket gets on this car, it will be crazy!
Old Jun 18, 2008 | 09:54 AM
  #53
SynapseTurbo's Avatar
when someone claims brake horsepower they dont mean at the brakes, but rather at the flywheel, the brake was just a mechanism they used for measurment.
although there are no wheels on the car, the dynapacks numbers are meant to be at the wheels. a dynapack actually measures torque where as a dynojet calculates horsepower based on the amount of time it takes to accelerate a drum. the biggest advantage of the dynapack is the steady state feature. this allows to dyno to lock the car at a certain rpm, and by applying a load to counteract the engine. This load forced the motor to sustain the same rpm but increases the load on the motor(imagine going uphill, more throttle but rpm doesnt move much). This allows the tuner to hit cell's on the tuning software they wouldnt normally be able to simulate without a load bearing dyno.
Old Jun 18, 2008 | 09:57 AM
  #54
krispy's Avatar
I thought it was original termed because they tested engines on water brake dynos
Old Jun 18, 2008 | 10:01 AM
  #55
originaladrian's Avatar
newer higher end dynojets have dynobrakes as well.
Old Jun 18, 2008 | 10:17 AM
  #56
it was a mechanical band brake. yes you can fit a dynojet with an eddy current brake but with higher torque car trying to hold the rollers back tends to product tire slip.
Old Jun 18, 2008 | 10:34 AM
  #57
an0malous's Avatar
id love to see a stock ss/sc dyno on that same dyno.
otherwise, these numbers, are just numbers.
no relativity
Old Jun 18, 2008 | 10:37 AM
  #58
ralliartist's Avatar
good info to know about dynos and such. Just goes to show that every dyno is different and unless 2 cars are measured on the same dyno, numbers are just numbers. It's more of a tuning tool.
Old Jun 18, 2008 | 11:10 AM
  #59
HackAbuse's Avatar
Originally Posted by Edubs
Wow, glad to see you guys got into the balts. I was out there a few months back when the Ryans from RD Fabs came out w/ the RHD civic. If you're going to get into HPT w/ the Cobalts, then I need to talk to you. Shoot me a PM when you have a chance. This is very good news cause Ryan and I are digging into a project this winter...
You mean Crack?
That guy is a joke around here.
Old Jun 18, 2008 | 11:15 AM
  #60
Edubs's Avatar
Originally Posted by HackAbuse
You mean Crack?
Care to elaborate? Shoot me a PM. I know the shop owner, Ryan D, very well. Their shop is no joke, nor their projects...
Old Jun 18, 2008 | 11:21 AM
  #61
HackAbuse's Avatar
:deleted:
Old Jun 18, 2008 | 11:36 AM
  #62
Edubs's Avatar
:deleted:
Let's take this out of Synapse's thread. You have a PM...
Old Jun 18, 2008 | 11:41 AM
  #63
HackAbuse's Avatar
Try again, my box was full
Old Jun 18, 2008 | 11:42 AM
  #64
Zven's Avatar
Thanks for the dyno post! This is great news. Someone correct me if I'm wrong, but aren't these detuned electronically for the first 500 or so miles? I noticed that you dyno'ed at a pretty young age. Like to see another dyno at around 600-700 miles.
Thanks again!
Old Jun 18, 2008 | 11:44 AM
  #65
Edubs's Avatar
Thanks again!
I believe that the first 500 miles are "sugar coated" by the PCM, I'd also like to see results after the car has a few more miles on it...
Old Jun 18, 2008 | 11:50 AM
  #66
Area47's Avatar
Rent me! per hour
Originally Posted by ralliartist
I'm not sure if it's a dynojet, but I know they make dynos with 4 rollers. I've seen them myself. There is one in Kansas City.
negative batman.
two rollers. front and rear.
this one is at modified by kc.
the other awd is a mustang at imagine auto. two rollers. front and rear.
wut?
if the car is strapped down correctly. the tires won't slip.
Old Jun 18, 2008 | 12:23 PM
  #67
krispy's Avatar
Originally Posted by Area47
wut?
depends on how much power its making, dynos do have limits
Old Jun 18, 2008 | 01:07 PM
  #68
chris88z24's Avatar
no relativity
Working on it. Give me a few days lol.
Old Jun 18, 2008 | 01:10 PM
  #69
Area47's Avatar
Rent me! per hour
i have personally witnessed an old shop car being held at 100mph on a mustang dyno. the said car put down 1130 to all for wheels. no slip. also used 8 chains, and 4 straps to hold it.
Old Jun 18, 2008 | 01:43 PM
  #70
firemanfrank's Avatar
... every dyno is different and unless 2 cars are measured on the same dyno
^Not to worry, it's in the works!
Old Jun 18, 2008 | 01:47 PM
  #71
krispy's Avatar
I never said the limits were low
Old Jun 18, 2008 | 01:49 PM
  #72
Area47's Avatar
Rent me! per hour
high, low, medium. fat, small, obtuse. it is all in how it is strapped down
Old Jun 19, 2008 | 12:50 PM
  #73
hp tuners just repsonded to me after i sent them the data from our cobalt. it looks like they should be able to support the cobalt ss/tc with their next update due out soon. this will open up many doors for this market.
Old Jun 19, 2008 | 05:48 PM
  #74
boostking's Avatar
can't wait!!!!!!
Old Jun 19, 2008 | 06:13 PM
  #75
hawkeyez's Avatar
I have an 06 SS/SC that I want to dyno here in Glenville
I have an 06 SS/SC that I want to dyno here in Glenville. Just hit me with a pm
