Turbo Swap info.
Old 06-06-2012, 12:09 AM
SuperSarahG5's Avatar
Turbo Swap info.
Hi. Looking to get some info on going turbo.
Currently the car is a stock 2.2 with an auto. I plan on going turbo with it, but keeping a stock engine and just running low boost.
I need to know what kind of intake manifold I should run. I'm sure the stock plastic one can handle low boost.
What kind of fuel setup should I run? I know bigger injectors. Do I need a different pump, or can I run a BAP?
What turbo should I use? Nothing too serious, but something that wont be a paper weight in a month.
Should I rebuild the trans? (shiftkit, stronger clutches, Stall, ect.)
Thanks for any info.
Old 06-06-2012, 12:14 AM
BankerBalt's Avatar
low boost you wouldn't necessarily HAVE to do much modification other than the kit
Old 06-06-2012, 12:35 AM
So other than injectors, the fuel setup it good?
How much can a stock 2.2 handle? I'm looking for about 300 to the wheels.
Old 06-06-2012, 12:45 AM
BankerBalt's Avatar
You may need a fuel pump. And what are you saying low boost is? I blew my balt up with 210 at the wheels... You'd be taking a HUGE risk anything higher than what i did...
Old 06-06-2012, 01:10 PM
Ok. Well I'm not looking to make a super powerfully street machine. Just looking to make it somewhat quicker. Maybe get about 100hp more out of it.
It's either turbo stock engine, or build an N/A engine.
By build I'm talking cams, pistons, crank rods. Something like a high comp 2.5 stroker.
Thoughts?
Old 06-06-2012, 01:25 PM
K-Train04RL's Avatar
Super charged power comparing to turbo. Sc seems to blow quicker and at less boost than tubo
Old 06-06-2012, 01:36 PM
So SC over turbo or high compression?
Old 06-06-2012, 01:42 PM
2009CobaltLT's Avatar
You can do the same setup as the Garrett kit had (before it was discod), which is the Garrett GT2860RS with their manifold/o2 housing which will bolt up to the factory downpipe. I have the mani/o2 housing for sale, so all you would really need is the turbo/intercooler/piping if you wanted it.
Stock fuel system will hold up fine except injectors. I would suggest 42# injectors.
Stock internals on the 2.2 can handle ~250
Any of the build threads in this link will have all sorts of info for you:
https://www.cobaltss.net/forums/2-2l...thread-208355/
Old 06-06-2012, 01:44 PM
07cobaltguy's Avatar
i was running 15psi on E85 making 115mph traps good for 12sec passes. Thats well in the 300whp range. I do not recommend it on the stock block, mine ended up with a window in block after 5 months.
Old 06-06-2012, 01:46 PM
you could do the SS setup with the K04 that would put you in the 220+ range and thats about as far as you want to go on the stock bottom. thats my recommendation to you.
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
ThoR294
10-04-2015 08:44 PM
maliki778
10-01-2015 07:39 PM
ThoR294
09-28-2015 05:31 PM
Quick Reply: Turbo Swap info.
