under boost/ boost leak
what exactly is or what causes under boost? i switched out my lower charge pipe last night. everything is tight. nothing is cracked or broken. also just installed zzp 3" full exhaust and catless dp. and even with my 22.5-23psi tune. it takes awhile to hit full boost. doesnt sound like a leak. but the higher the rpm the more boost i get. and even the tuned ecm i have it only hits like 16 psi. any recommendations??
Hey Pervert, it was something easy like a loose nut! You should read some bulletins and fix some cars instead of talking about blowing up your POS Neon! Ahhahaha
The only loose nut is you. Stop giving troubleshooting advice, thanks.
n20saturn
Sep 30, 2015 12:26 AM
