under boost/ boost leak
Old Jan 15, 2013 | 06:28 PM
TY8425's Avatar
what exactly is or what causes under boost? i switched out my lower charge pipe last night. everything is tight. nothing is cracked or broken. also just installed zzp 3" full exhaust and catless dp. and even with my 22.5-23psi tune. it takes awhile to hit full boost. doesnt sound like a leak. but the higher the rpm the more boost i get. and even the tuned ecm i have it only hits like 16 psi. any recommendations??
Old Jan 17, 2013 | 09:31 PM
4g63killer's Avatar
Deffinately boost leak! If unable to test at least make sure couplers are seated properly and don't be afraid to crank down the tbolts! Also check map screws in lower cp make sure everything is tight!
Old Jan 18, 2013 | 11:18 AM
prevsrt4owner's Avatar
Sounds like a boost leak. Boost Leak test with soapy water. There's a video that shows this for the LNF. Let me know if it's necessary.
Old Jan 18, 2013 | 10:27 PM
TY8425's Avatar
It was my waste gate flapper. The nut on the drivers side of the flapper bracket vibrated off the actuator shaft. Gate was stuck OPEN.
Old Jan 20, 2013 | 01:43 AM
Muncie's Avatar
Hey Pervert, it was something easy like a loose nut! You should read some bulletins and fix some cars instead of talking about blowing up your POS Neon! Ahhahaha
Old Jan 20, 2013 | 10:49 AM
You're still heartbroken and sour after the episode. How are the wounds healing?
The only loose nut is you. Stop giving troubleshooting advice, thanks.
Old Jan 20, 2013 | 02:01 PM
SSlobalt's Avatar
Someone please link me to this drama.
Old Jan 20, 2013 | 02:09 PM
Lol, not even worth it, man. This guy is around 55/65 and talking so much smack. He's blown engines. I haven't blown a single engine in my life.
Old Jan 20, 2013 | 02:17 PM
SSlobalt's Avatar
I'm 42.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
