Urgent mechanic help needed
There's no check valve where the condensation pipe is plumbed in. So if moisture can get into the condensation pipe from the intercooler, where do you think air is going?
I have a 2010 with boost gauge and it was still building pressure. does this mean I am OK, or could I still have issues? Can I just JB weld the condenser back to the IC?
What kind of damage could this do to the engine if it is not quickly repaired?
IF YOU HAVE intercooler piping too the bottom one could have came this connected from the intercooler happened to me once, had a major back fire and no boost, connected it back up and was on my merry way
On my way home I got a check engine light and car was running sluggish.
I unscrewed the other side and jb welded the holes, but still have check engine light and no boost. What else could have happened when I hit the pot hole? I think something else is cracked
Also check both plastic ends of the IC to make sure you have no cracks.
Boost leak test how-to in my sig.
Ordered a ZZP IC. Anyone know how quick these things ship? I don't want to drive a lot with this crack. Is this going to harm anything if I drive a week with no boost? Right now the only bad thing is its slow as sh*t, but I can deal with that.
GM should've made it a recall and removed all the condenser tanks...Oh well, I've only read good things on zzp and was planning on upgrading to that eventually anyways.
No problem
You don't take the end tanks off lol.. The thin piece that runs below the IC can be removed so it doesn't get hit and possibly crack your end tanks.
agentirons
Oct 16, 2015 02:11 AM
Iceberg
Sep 29, 2015 12:33 PM
