Urgent mechanic help needed
Old Apr 20, 2011 | 11:35 AM
Wangspeed's Avatar
Originally Posted by kidcrash603
I don't though.
I still boost to the same levels, no strange noises, no cels, and nothing strange on my logs....
What you don't have on your logs is real EGT and turbo speed. You're overspinning the turbo to compensate for the boost leak.
There's no check valve where the condensation pipe is plumbed in. So if moisture can get into the condensation pipe from the intercooler, where do you think air is going?
Old Apr 20, 2011 | 11:43 AM
Iam Broke's Avatar
^^^ Not to mention the unfiltered and unmetered air getting sucked in at light throttle/no boost.
Old Dec 9, 2011 | 01:53 PM
Galby's Avatar
Originally Posted by donkeyballs
After you plug the holes and if its not boosting you probably broke the end tank.. But you should be able to patch it and limp it around till you get a IC.
This same thing happened to me today. I broke the little plastic piece holding it up on the right side of the condenser (looking at the car from the front).
I have a 2010 with boost gauge and it was still building pressure. does this mean I am OK, or could I still have issues? Can I just JB weld the condenser back to the IC?
What kind of damage could this do to the engine if it is not quickly repaired?
Old Dec 9, 2011 | 02:05 PM
yamaha288's Avatar
^^^ just unbolt the other side put some jb weld in the holes and leave the condenser off problem solved and it wont happen again
Old Dec 9, 2011 | 02:19 PM
Galby's Avatar
OK I will try that. I just wanted to make sure the IC is OK. Are there just 2 holes (one on each end?)
Old Dec 9, 2011 | 02:23 PM
steven2008ss's Avatar
IF YOU HAVE intercooler piping too the bottom one could have came this connected from the intercooler happened to me once, had a major back fire and no boost, connected it back up and was on my merry way
Old Dec 9, 2011 | 02:26 PM
donkeyballs's Avatar
Its just on one side and the other just hangs .
Old Dec 9, 2011 | 02:56 PM
nobody2u's Avatar
So everybody should remove their condensation pipe even if they haven't broken it yet?
Old Dec 9, 2011 | 04:19 PM
SSlobalt's Avatar
It has been recommended, but I would just buy a metal IC (like I did) and get it over with.
Old Dec 9, 2011 | 04:31 PM
nobody2u's Avatar
Probably doesn't fit in my budget till next year. So if I'm gonna roll on the stock IC I should take it off then?
Old Dec 9, 2011 | 05:21 PM
  #36
Galby's Avatar
On my way home I got a check engine light and car was running sluggish.
I unscrewed the other side and jb welded the holes, but still have check engine light and no boost. What else could have happened when I hit the pot hole? I think something else is cracked
Old Dec 9, 2011 | 05:26 PM
  #37
Go to a parts store and have them run the codes and clear it. Or try to disconnect the battery for 15min but i would check the codes. If it still feels not right i would do a boost leak test.
Also check both plastic ends of the IC to make sure you have no cracks.
Old Dec 9, 2011 | 10:28 PM
  #38
SSlobalt's Avatar
Boost leak test how-to in my sig.
Old Dec 10, 2011 | 12:21 PM
  #39
Galby's Avatar
Wow...wish I had known about these plastic IC ends before hand...Got a 3" crack on the side with the 2 holes (cold side I think).
Ordered a ZZP IC. Anyone know how quick these things ship? I don't want to drive a lot with this crack. Is this going to harm anything if I drive a week with no boost? Right now the only bad thing is its slow as sh*t, but I can deal with that.
GM should've made it a recall and removed all the condenser tanks...Oh well, I've only read good things on zzp and was planning on upgrading to that eventually anyways.
Old Dec 10, 2011 | 12:27 PM
  #40
JB quick weld the crack till you get the IC.
Old Dec 10, 2011 | 01:21 PM
  #41
Galby's Avatar
Just did. Hopefully it dries/seals. Thanks for the help!
Old Dec 10, 2011 | 03:03 PM
  #42
nobody2u's Avatar
Any downside to taking the endtanks off your stock IC to prevent this? Or is it just there to hold pointless liquid?
Old Dec 10, 2011 | 03:10 PM
  #43
No problem
You don't take the end tanks off lol.. The thin piece that runs below the IC can be removed so it doesn't get hit and possibly crack your end tanks.
Old Dec 10, 2011 | 04:04 PM
  #44
nobody2u's Avatar
No problem
Gotcha thanks.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
agentirons
Oct 16, 2015 02:11 AM
Iceberg
Sep 29, 2015 12:33 PM
