who makes wheels that clear the brembos
#128
#129
Thanks! The light comes on, but that doesn't bug me too much. How would I know if there are any "codes" thrown? A couple of chimes on startup, then the light stays on as a warning. No big deal for me. Keep in mind that "plenty of clearance" is with those small 3mm spacers. You can see a pic of them in my web album. Without the spacers, there's about 1mm of clearance, which is too close for me.
#130
+1 Anybody know of any steelies that will fit hahaha..........seriously haha. I know theres 17"steelies on cars like the Saturn Aura and maybe the new Malibu i think. However, I cant find any other measurements on them so I dont know if theyd even come close to clearling the brembos.
#131
Hey, don't know if this would help you guys, but do the stock SS/SC 18" rims fit your TC models?? I used my stock 18" rims on my 2006 SS/SC with snow tires. I found a set of used snow tires on Ebay, in 18" size. They came off a Porsche. I think I have seen them before on tirerack.com. They were the same brand as came stock on the SC's, Pirellis. They are actually a real nice tire, and grip better than my stock summer tires. There is a winter snow tire tread pattern, but still a real nice performane ride. They were a little expensive, but you could probably find stock 18" rims for less than $400. It would not matter if your winter rims had a little curb rash already, right? Should be able to find them cheap. Hope that helps.
#132
#133
hmm...well, there goes that idea....you guys could still use the idea of the 18" Pirelli snowsport tires..... There are not many snowtires made in 18", mostly 16", some 17".....
Why is is the stock SC rims don't fit?? Is the off-set different?? The rim width??...I guess I figured if the sctock TC rims fit the SC model......????
#135
This shouldnt be as hard as it is. Although I will be driving my mazda, I would like to think worst case, I could pull the balt out into the white stuff should times warrant it. I called around to several places. I called dealerships too and no one knows anything, even if you give em a VIN. One shop guy I spoke to was "You give me the vin, and I can tell you, the vin lets us know everything you need to know about that car, including tire and rims"... Then he called back 5 min later to say "Sorry I have no idea, my system doesnt tell me anything..." lol F'kin GM
![Smile](https://www.cobaltss.net/forums/images/smilies/smile.gif)
#136
#137
What size spacer though? Thats another question that varies. I can live with 3mm due to the fact I "should" be able to hub center the wheel. Even still I would want to use the same spacer in the back, and some say dont? I mean, what so good about having you're front wheels out farther than the rear wheels? Some wheel places are stating 20mm spacer may be needed. Thats terrible.
Interesting, I wonder how this is all going to pan out for us TC owners. One thing I do know, the market is wide open for a wheel manufacturer to offer a winter tire / rim solution for the 08 - 09 TC
#138
1 Post
And that goes for everyone in this thread. I am sick of reading all these complaints You guys have the lug pattern and offset...try test fitting and stop whining.
![Lockd](https://www.cobaltss.net/forums/images/smilies/lockd.gif)
Also, why would you want to run a spacer in the back? What logical reason is there to run one?
#139
ok I'll ask a neb question what do wheel spacers look like( anyone have a pic?), and what additional wear and tear if any is involved if I find a set of sc rims and wanted to put them on the tc for the winter?
#141
Stop being a ***** and start test fitting some wheels!
And that goes for everyone in this thread. I am sick of reading all these complaints You guys have the lug pattern and offset...try test fitting and stop whining.![Lockd](https://www.cobaltss.net/forums/images/smilies/lockd.gif)
#142
Mal.
Mal.
#143
Who's saying I havent? Tried 2 different sets of 17 steelies and one set of 17 konigs that didnt fit with a 12 mm spacer and I wasnt going any higher than that. The ones out there getting close seem to be down to 3mm and the point I was making was that I am ok with that. As far as only using spacer in the front, just making a statement it doesnt make much sense to me.
Dont ASSume so much, you won't be as upset when you read chat forums
#144
Dont ASSume so much, you won't be as upset when you read chat forums![Smile](https://www.cobaltss.net/forums/images/smilies/smile.gif)
#145
1 Post
Which 17" steelies did you try? Pics?
Also, why would I run a spacer in the rear if I have no clearance issues?
And stop being such a pansy. Ass!
#146
Hahaha, quit youre whining ass-jack ! I was making a collective statment that none of the 2 steelies OR konigs fit, so pics are pointless unless you like to see what a rim looks like that doesnt fit....
When/If I find a solution other than storing my car for the winter I will be sure to post all the details.
With a 3mm spacer I wouldnt be concerned but having my front wheels sticking out 20 - 30 mm more than my rear does.
#148
Apparently a local tire and rim guy here has fit two TC's with a 17 inch steelie.... hmmmm this may be pic worthy. He quoted me 1280 for rims tires installed + tax... I will post back if this works. He asked "Is that the model with the Brembo's?" so I am encouraged.
#149
1 Post
The pic was actually so I can reference what you tried. I have yet to try the 17" steelies off my co-worker's 2008 Saturn Aura, but these wheels hold promise...
#150
Yes they do. I "just" found out there is a 17" steelie that will cover the brembo's. As soon as I encouter this magical rim, I will be sure to post a pic and contact info. I just want to verify this info first.
