Zzp PCM spiking boost at 28psi?
Old Oct 14, 2011 | 08:42 PM
etnies's Avatar
It holds a steady 25lb but it's suppose to stop at 22lb I'm worried about the air/fuel ratio cuz all I have is the stock boost gauge. No check engine light and I've not put the gm stage one sensors in it yet
Old Oct 14, 2011 | 08:54 PM
Chevycobaltss3's Avatar
If its tuned for gmstg1 put them in......
Old Oct 14, 2011 | 09:04 PM
etnies's Avatar
Ok man didn't know it made a difference since they were optional
Old Oct 15, 2011 | 01:24 AM
Yeah if your tune was made for the gmstage1 sensors then your sending incorrect readings to the ecm...
Old Oct 15, 2011 | 04:43 AM
etnies's Avatar
Now just the aggravation of that lower sensor and I'm done
Old Oct 15, 2011 | 09:16 AM
Lmfao yeah burn it hahahaha
Old Oct 16, 2011 | 04:21 AM
etnies's Avatar
well i got em both in last night but the bottom one refused to go it and i ended up breaking the oring but then i put the best fitting one i could buy on it and yet it leaked air like a mother and threw it off horribly when it made boost lol of course.........
but now idk where to get a o ring that fits it and is small enough to fit in this hole
Old Oct 16, 2011 | 08:11 AM
Wangspeed's Avatar
Did you cut the plastic boss off like the GMS1 instructions say? Also you see supposed to lube the o ring with either clean oil or silicone grease. The right size ring is 202. I got a pack from Mcmaster Carr. They are a little tough to get onto the sensor but just use some small metal picks and a little silicone grease or clean engine oil.
O Rings for GMS1
Old Oct 16, 2011 | 09:19 PM
etnies's Avatar
O Rings for GMS1
What you mean the plastic boss? All it came with was instructions on wiring and I got it from zzp Not that that should make a difference just sayin
Old Oct 16, 2011 | 09:58 PM
Wangspeed's Avatar
The lower sensor will not seat unless you shave the plastic boss off. Look up the instructions on CED's site.
Old Oct 17, 2011 | 10:17 AM
etnies's Avatar
ok so i got to looking around and found what you ment by the boss. but I dont have a stock setup as for the charge piping but ill check it anyways but heres the real problems im having.......
1. the standard oring will not fit.
2. the sensors arent the same, they have a different serial code and the instructions from gm doesnt say anything about it....I read them and tried to find anything saying which sensor goes where but nothing.....
Old Oct 17, 2011 | 11:45 AM
Matt M's Avatar
Are you saying the two sensors you received have different serial numbers? Or different part numbers? Both sensors should be exactly the same, regardless of the serial numbers.
Old Oct 17, 2011 | 12:43 PM
Can u post a pic so we can help u out identifing the maps.
Old Oct 17, 2011 | 01:14 PM
etnies's Avatar
I just switched them around and guess what....the other one fit the charge piping perfectly so im assuming i had them backwards.....
checked my wiring to make sure it was all good and now im gonna order a o ring or two and i went ahead and put the permatex on the sensor with a small oring so soon as that cures ill be driving it once more and ill let you guys know how it goes
if this fails then ill diffenatly send in some pics
Old Oct 17, 2011 | 03:28 PM
etnies's Avatar
ok so everything is good to go....its running perfect....no check engine light, it pulls like crazy but its blowing more black sut then ever and when you stop or anything you can smell sulfur or something....idk if its right and im kinda worried? or is this just normal
Old Oct 17, 2011 | 04:08 PM
THE BLACK SMOKE is normal for a car with a rich afr.... The sulfer you smell is if your catted. if your not catted make sure theres nothing burning. Also id be happier with a pic of said map sensors..!!
Old Oct 17, 2011 | 06:08 PM
Matt M's Avatar
Old Oct 17, 2011 | 07:21 PM
I know what they look like. Hence.. I have them as well and installed many. I want to know how his look since he said they were different.
Old Oct 17, 2011 | 10:21 PM
Matt M's Avatar
I know. I was just saving him the trouble. I pulled them out of the same box as these to ship with his ecm.
Old Oct 17, 2011 | 10:27 PM
Oh lol.... Yea i wonder if he mixed up stockers with the gmstg1'z lol
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
