1/2 E85 1/2 93 Octane
Old Mar 17, 2011 | 09:27 AM
Spins All Day's Avatar
I am going to be doing a 1/2 E 85 tune and a half 93 octane tune today. Is there anything I need to know about the injector duty cycle and the pressure rail or will the car not need any adjustments.
The car made 315 WHP before hoping for 340 WHP on 20lbs of boost.
The injector duty cycle should be fine for that correct?
Old Mar 17, 2011 | 09:35 AM
batboy's Avatar
A 50-50 blend should be ok with stock fuel pump and injectors at your power levels. Obviously, you need a proper tune for the ethanol blend. Just make sure the tuner knows what he's doing.
Old Mar 17, 2011 | 12:28 PM
RyRidesMotox's Avatar
Wait for the straight E85 tune coming from vince. Once everything is dialed in it would be worth it.
Old Mar 17, 2011 | 12:43 PM
As of right now the car is throwing a fuel pressure code but my tuner says the fuel is there. We are going to turn it off and see if it pops up again. If it does how would we up the fuel pressure nothing is allowing him to do that with hptuners.
Old Mar 17, 2011 | 12:59 PM
MS3 2 SSTC's Avatar
I second this!!!
Old Mar 17, 2011 | 01:06 PM
Iam Broke's Avatar
If you are already popping the Fuel Rail Pressure CEL, it's gonna get a lot worse on the 1:1 blend. You need ~14% more fuel for it. You have an issue somewhere if you are getting low fuel pressure at that horsepower level.
Look for a restriction in the line going into the HP Fuel Pump.
Personally I wouldn't disable the Low Fuel Pressure CEL & Reduced Eng Pwr.
Currently Trifecta is the tune that can raise the fuel rail pressure setpoint.
Old Mar 17, 2011 | 02:42 PM
You need to be running hte Trifecta base and hp overlay... just as Iam Broke said. HP can only get you so far.
Old Mar 17, 2011 | 02:46 PM
sundevil07's Avatar
Where are you getting 93 in Arizona???
Old Mar 17, 2011 | 03:50 PM
drewbroo's Avatar
yeah do tell. I miss my east coast OCT
Old Mar 17, 2011 | 03:52 PM
drewbroo's Avatar
I got this code a few times before I melted a piston. My rail popped on CYL one, and was leaking.... I gave it part throttle one day and nuked my engine.
Old Mar 17, 2011 | 08:15 PM
I had him reset the code so if it comes back on I will have to get it checked out.
The car ended up making 328 WHP. I picked up 13 WHP from the E85.
Old Mar 17, 2011 | 08:35 PM
Iam Broke's Avatar
Good decision on the P0087! That way if it pukes, it'll reduce the powa!
If you need a fuel rail if yours leaks, I have one service tested to 2800 psi.
Old Mar 17, 2011 | 10:12 PM
We had a **** load of trouble finally getting the car to run well.
We had to replace the plugs and gap them to .29, but before that the car was just not making power and not running well on the E85. After the plugs went in the car started to run a lot better.
I hope the fuel pressure issue was related to the plugs but we will see in the next few weeks.
I guess the code that I should be looking for is a P0087 my tuner didn't tell me the exact code #.
Thanks man.
Old Mar 18, 2011 | 10:10 AM
Terminator2's Avatar
If you are getting a low rail pressure code on gas do not do a ethanol blend you WILL pop a piston due to fuel starvation.
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
roadrunner132
Sep 16, 2015 09:13 AM
Macgyver2484
Sep 2, 2015 05:44 PM
