110 Octane
Old Feb 23, 2012 | 10:43 PM
Frogstofall's Avatar
Matt's car may have been at the point where he wouldn't gain anything by using it but you should see SOMETHING I would imagine if you were tuned for it.
Old Feb 24, 2012 | 08:58 AM
Kbbalt's Avatar
Yea thats what i saying obviously with a tune you should see something, Unless Apr is that bad ass?
Old Feb 24, 2012 | 09:03 AM
Well the VDubs may be so bottled up that it makes a huge difference for them. There's no denying you should be able to run a bit more boost and timing with a higher octane fuel so just get tuned for it. You may not see E85 numbers but I have a hard time believing you won't see ANYTHING.
Old Feb 24, 2012 | 09:08 AM
klloyd's Avatar
I buy my meth from Speed Unlimited since it's right outside the of the base. I thought about running 110 but with the price then having to drive up to PA for a tune tweak it's just not worth it right now.
Old Feb 24, 2012 | 10:46 AM
Kbbalt's Avatar
Yea im right around the corner from from Speed Unlimited also, He can send tweaks via email hp tuners, if you save the file
Old Feb 24, 2012 | 02:54 PM
Matt M's Avatar
What makes running 110 different on the LNF than on many other turbo motors- Running 110 typically makes more power because you can add more boost, add timing, and lean out the mixture. However, with supporting mods on the LNF, you can already max the stock turbo and run a 12.8:1 afr on 93 octane. This takes away two of the three advantages that you can normally utilize. Spark timing is also different on the LNF than on most other motors. The design of the piston makes injection timing and placement critical which may require some adjustments to get the most out of slower burning, higher octane racing fuel. Yes, you can get gains from 110, but don't expect more than a few hp at best. On the LNF, gains from Ethanol or methanol are mostly from the increase in energy availble from the overall amount of fuel being burned.
Old Feb 24, 2012 | 02:57 PM
Gremlin85's Avatar
Hey Matt, did you try leaning it out a little further than 12.8:1 at all on the 110 Octane?
From my understanding, these motors respond better to AFR changes than timing.
Old Feb 24, 2012 | 02:59 PM
Matt M's Avatar
Yes, I believe I ran 13.0-13.1 or right around there.
Old Feb 24, 2012 | 03:01 PM
Gremlin85's Avatar
In the back of my mind I knew you guys did lol.
No stone left unturned
No power increase I'm assuming?
Old Feb 24, 2012 | 04:29 PM
Matt M's Avatar
It's been a while, so I don't remember the exact numbers, but I do remember that we were pretty disappointed because the gains were next to nothing.
Old Feb 24, 2012 | 06:39 PM
  #36
Great info here. These are the kinda posts I enjoy reading. More please.
Old Feb 24, 2012 | 08:53 PM
  #37
Kbbalt's Avatar
How the hell did i miss that, Reading Fail on my part....LOl Thanks for pointing that out Frogstofall
Nice color balt also
Old Feb 24, 2012 | 10:09 PM
  #38
I like your car's color too. What a coincidence.
Hugger1975
Oct 15, 2015 03:28 PM
twilson380
Sep 14, 2015 10:52 AM
Macgyver2484
Sep 2, 2015 05:44 PM
superbooster
Oct 13, 2005 03:49 PM
