2010 Cobalt SS/TC Stage 1 test drive!
Old Aug 22, 2009 | 11:40 AM
  #151
Terminator2's Avatar
Originally Posted by buellfooll
Please don't take any offence but I, for one, will accept the word of the engineer that designed this thing before that of an aftermarket product deigner/developer/seller looking for sales.
These GMPP guys have been pretty straight with us and I don't really think they're trying to pump up the product. They could easily just tell us "the learn down is gone" and leave it at that but they go on to say the turbo protection features are still there and may SEEM to MIMMICK the learn down to the uninitiated. They also wouldn't tell us our bolt ons are now actually going to work with the upgrade, if it wasn't something that will prove itself out soon, which is further proof the "learn down" will be gone. Those that have delayed their aftermarket add-ons for after the installation of the upgrade will probably see and feel the difference in peformance better than those that already have the bolt-ons installed (we will have nothing to compare it against) and I wait for their comments after all their mods are in place.
This is NOT to say that the aftermarket is wrong in what they believe. Some of them have definately advertised some big HP and torque numbers. But we in the general Cobalt SS buying public have to put our faith and trust in SOMEBODY and who better than the people that designed this upgrade from the ground up.
I am NOT flaming. Just stating my feelings and opinions like everybody else.
Ok. I respect your opinion but having seen the inner working of the ECM there is no doubt that the boost will not go up much as you add mods to the stage tune. BartSS's HHR never made 26 psi on the stage tune with Catlless DP IC CB exhaust and CPs. It stayed at 22 psi or so. But once you tune on top of the stage tune there can be massive torque gains.
Old Aug 22, 2009 | 11:49 AM
  #152
steddy2112's Avatar
You can actually see where it spins up to...instead of kinda guessing
Also you get to hold it longer...so more is made I presume.
Hey term, is it the exact same tables to tune with?
Old Aug 22, 2009 | 12:00 PM
  #153
More_Torque_More_HP's Avatar
Here is some more explaination. First we don't control boost PSI. It is a result of the he desied air flow, inlet air temperature, barometer/altitude, etc.
second 22psi with the stage kit gives 280 HP. You add a fresh air - free'r flowing - intake and a free'r flowing exhaust the same 22 psi will give you more HP because you have removed restrictions in the system and you will be flowing more air.
Old Aug 22, 2009 | 12:10 PM
  #154
That is exactly what I way saying the Max airload torque table, desired airloads and optimum engine torque table control the airflow via the electronic throttle and the wastegate on the turbo the are converted into desired boost basically. What a lot of people think is that if you add mods to the stage tune it is going to raise the the boost level and that is what most refer to as the learn up or learn down feature. Airflow can increase without the pressure level increasing that is what many do not understand.
Old Aug 22, 2009 | 12:49 PM
  #155
redcomet303's Avatar
ordered my kit from ced last night and my lowest quote was 140 install for the tune only meaning I will have to do the splicing myself, MORE_TOUQE_MORE_HP can you verify for me that me installing the sensors ( and by the way I am an electronics technician with years of experince in soldering) will not void my warrranty they wanted an extra 100 to do the sensors I just want to get the best deal I can on the install the price for the kit was no problem I would rather pay gm than any aftermarket company for a tune for my engine with warranty.
And when the intake comes out GM will have more of my money.
Old Aug 22, 2009 | 01:29 PM
  #156
boostking's Avatar
Key word: Desired
The production cals will take action on many fronts to take you back to deisred. Stage kit will take no action to bring you back down to desired. Soooo....if you have add ons that give you more than deisred they are not learned out or down. Example a fresh air intake will give you more than desired. Production-learned down, stage kit no action taken.
Both still have the turbo protection features: over boost and turbine overspeed.
Bill if you get some free time it would be great to have a write up of whats going on within the computer and what needs to happen in order for us (big turbo, not worried about warrenty guys) to get the power were looking for. I'm not sure if you can but if hptuners had some more insight on what needs to happen we all would be in a much better place!!!!
Have you looked at hptuners and seen how we control boost, timing etc and would you give some insight on if were on the right track with the current tables aval?
Old Aug 22, 2009 | 07:40 PM
  #157
Desired and actual are not the same anyway if you crank them as the stock turbo can move only so much air especially past 6200 rpms. Does the stage tune OS change any of the 600 fueling tables in the ECM?
Yes the fueling, spark, cam timing have all been updated and optimized for the required premium fuel.
Stage kit max RPM is raised to 6500
Sorry I can not "give away" GM secrets. So un decoded/undected calibration parameters are out. I can not discuss them.
HPTuners has not yet broken "the code" on the fueling you "big Turbo" guys really need. So HP Tuners needs more work there.
Last edited by More_Torque_More_HP; Aug 22, 2009 at 07:40 PM. Reason: Automerged Doublepost
Old Aug 22, 2009 | 07:45 PM
  #158
buellfooll's Avatar
Thanks Bill. I just wanted to bring out the point that boost wasn't the only thing that changes with the upgrade. I'm looking at the pictures and I think I'm seeing a different intake than on my 09 sedan? Care to comment?
Old Aug 22, 2009 | 07:53 PM
  #159
FRQ FLYR's Avatar
^ x2. And more importantly have the SS hats been released?
Old Aug 22, 2009 | 07:59 PM
  #160
CobaltSSilver's Avatar
Which pic where?
Old Aug 22, 2009 | 08:06 PM
  #161
ssyellow's Avatar
Originally Posted by CobaltSSilver
Which pic where?
in me thread, kinda confused at what hose he is talking about tho...
Old Aug 22, 2009 | 08:26 PM
  #162
rukkee's Avatar
I'm pretty sure its the coolant line that he's talking about.
Old Aug 22, 2009 | 08:31 PM
  #163
ssyellow's Avatar
he he I know, just want to make sure thats what he sees lol.
Old Aug 22, 2009 | 08:59 PM
  #164
I will try and get a picture of the underhood. Intake and intercooler pipes are unchanged from the 2009 coupe. I have not looked under the hood of a sedan to see if they are different than the coupe.
Old Aug 22, 2009 | 09:55 PM
  #165
KillerBee's Avatar
Eveythign on the car is exact the same. I am goign to post my review on the first pager here in a minute. The 2010 comes with black radios and black ac controls supposedly. Anyways tlake on here has some pics of under the hood. He has a trifecta tune ss/tc and he was there with us.
Review posted!
Old Aug 22, 2009 | 10:57 PM
  #166
jsscooby's Avatar
Glad to see that right up. Im really wanting it now.
Old Aug 22, 2009 | 10:59 PM
  #167
Routs's Avatar
Great job KB!
Old Aug 22, 2009 | 11:01 PM
  #168
KillerBee's Avatar
Yeah its gunna be worth ever Pennie of it!
Originally Posted by Routs
Great job KB!
Thanks any questions ask away!
Old Aug 22, 2009 | 11:27 PM
  #169
80vetteL82's Avatar
I will be at Great Lakes Crossings from about 1:00 to 3:00 pm today, Saturday August 22nd, in front of Bass Pro. I have a red Cobalt SS and will be wearing a tan SS hat. If you can make it come on out and experience the Stage 1 kit
Hey Bill....have you ever wanted to visit Boston...**cough cough** haha I want the Stage 1 experience too! lol
Bill, will a "free'r" flowing intake and exhaust added to the Stage 1 void the warranty?
Last edited by 80vetteL82; Aug 22, 2009 at 11:27 PM. Reason: Automerged Doublepost
Old Aug 22, 2009 | 11:37 PM
  #170
rockstar014's Avatar
i want one!!!
Old Aug 22, 2009 | 11:47 PM
  #171
KillerBee's Avatar
just waiting for California for the CARB to go through once it does then the tune will be out! It can be any day or a month or so lol
Old Aug 23, 2009 | 12:00 AM
  #172
PimpLay2's Avatar
i may trade my 08 for a 10 what u think?
**** no im getting a 370Z
Old Aug 23, 2009 | 12:11 AM
  #173
KillerBee's Avatar
good luck with that! You can spend that kinda money on another better car!
Old Aug 23, 2009 | 02:07 AM
  #174
L.P.'s Avatar
Good review...but for instance my Trifecta Tune is pushing 22 lbs of boost and I am making 307/361 a lot better than the GM tune IMO. Yes of course its going to keep the warranty but I believe with Trifectas hide a tune for many dealers the tune will really go undectable. Its good GM is finally bringing this to the market but I really don't see the point of spending so much money on some sensors that we really don't need so much anymore and a shitty tune. People have broken the Gm stage 2 tune apart for the SS/SC and seen quite a bit of inefficency. All on opinion though.
Old Aug 23, 2009 | 02:12 AM
  #175
KillerBee's Avatar
Its understandable. But see where people are failing to realize is that GM has to make a tune that is suitable for all states emissions wise and the ability not to blow up the car. I am not a hard core all racer and I use my car for a DD so the stage kit gives me more hp and tq and keeping my warranty intact. Dealers probably cant detect the hidden tune but if something serious happens and need a new turbo or engine the first thing they do is dissect the pcm.
