2nd time at the track in my TC
Old Nov 24, 2008 | 05:25 PM
FF_ace's Avatar
Originally Posted by Psykostevo
Hahn also has 18 years of drag racing experience.
i have 2 weeks. im getting better the more i go.
Old Nov 24, 2008 | 05:29 PM
cakeeater's Avatar
should easily be trapping 110 at that power level. good job man.
Old Nov 24, 2008 | 05:31 PM
FF_ace's Avatar
thanks guys
Old Nov 24, 2008 | 05:35 PM
1WhiteSSTC's Avatar
Originally Posted by FF_ace
thanks guys
just think, the best stock ss/tc 1/4 mile was 13.6 STOCK, lol just imagine wat you'll be doing in the near future
Old Nov 24, 2008 | 05:42 PM
FF_ace's Avatar
ya im just trying to pick the brains of people that race a lot and try and get better myself.
Old Nov 24, 2008 | 05:48 PM
glhs379's Avatar
but mph is an indicator of hp, and not of driving experience, right,
et would be an indicator of lack of traction/driving exp, or both.
great times,
I was just saying hahn's car without a dp or IC upgrade was moving a bit faster at the 1/8 mile, and not on stock tires either.
but none the less, some good top end, especially for the 2nd time out racing!
Old Nov 24, 2008 | 05:51 PM
cakeeater's Avatar
great times,
not necessarily. you aren't going to trap as high if you can't shift as quickly or at ideal shift points. a better launch doesn't ALWAYS mean lower trap either.
Old Nov 24, 2008 | 05:52 PM
1WhiteSSTC's Avatar
lots of time practicing is your best friend, my best run on my first night at the track was 14.4 with a shitty launch cause it was get down towards near freezing temps.
Old Nov 27, 2008 | 12:38 AM
SportredSS's Avatar
Gosh!
Originally Posted by umrdyldo
god i'd hope you were in the right lane. Nice Job man.
You people don't read do ya... Says what lane in his post...
GEEEZ nobody reads or can't read his post, how sad, LOL!!!! Says what LANE and MODDS..... Damn!!!
can't wait to see your times when u get some good R/T and 60ft times, would love to see a mid 12s run.
Reaction times have NOTHING to do with your 60' or quarter mile at all..... He needs DR's..... I was there....A cold track at night ='s bad grip.... the AM sun (930-11 am) would warm the track surface enough to cut his 13.5 to a 13 or 12.9 alone.... It's also, LIKE HE SAID... his second time at the track and he's learning to understand the car\powerband more......
I'm waiting for someone with a TC to use the 4500 rpm launch dump<<< from a tune with drs or slicks w\grip, I'll bet 1.8 60's..... on a WARM TRACK....
top end is very good, but 1/8 mph is at 84?
a little low
about what hahn was running with his 107 mph pass.
but then again he was running sticky tires, but he had no IC upgrade or DP
DP and IC will give maybe 17-19 whp, enough to see nearly 109mph... We were spinning our tires nearly through the 1/8th.. I've the same bolt-on mods without CAI and mtr mts, I was squealing tires in all of second and most of third..... Track was just too cold!!!! A warm track in warmer temps 55-65*..... would make a huge difference.. I ran a 13.6 at 107mph in 100 degree air at 10 pm at a track alt of 1200 ft ( Firebird in Phx) and a DA of 4400' due to humidity in the 60% range and dew points in the mid 50 degree range.
Last edited by SportredSS; Nov 27, 2008 at 12:38 AM. Reason: Automerged Doublepost
Old Nov 27, 2008 | 01:27 AM
cobaltssoverbooster's Avatar
i havent raced alot but a front wheel line lock that has a button that has to be held down to enable, so when released it shuts off and goes to normal brake sounds like it would be helpfull for us to spool the turbo without doing a tripple pedal.
does that sound good or am i just a stupid tard?
Old Nov 27, 2008 | 02:29 AM
  #36
cakeeater's Avatar
then you'd have to hold the clutch pedal in anyway or you would ROAST your clutch and stall.
Old Nov 27, 2008 | 02:44 AM
  #37
drew1991sf's Avatar
then how do i have same trap speed as ppl doin 14's
Old Nov 27, 2008 | 11:42 AM
  #38
ah ha i see now thanks
Old Nov 27, 2008 | 01:07 PM
  #39
MARIN007's Avatar
Seeing these traps and dyno numbers always makes me want to take a road trip down to the infamous psykostevo, haha.
To the OP, don't worry about this run, really. Next time you're out, I bet you'll cut 2.2's in the 60'. You'll do better each time. If you don't, I'll hold your family hostage and not even Harrison Ford will be able to save them. ;p
Old Nov 27, 2008 | 01:28 PM
  #40
LE5_AJ's Avatar
he'll get chuck norris then
Old Nov 27, 2008 | 01:43 PM
  #41
cakeeater's Avatar
what do you mean? what are you running. Two similarly setup cars will almost always have a close trap speed, but just beceause a car traps one speed doesnt mean it can't trap significantly more at the same power level.
Old Nov 27, 2008 | 01:49 PM
  #42
chris88z24's Avatar
Damn, now I have to pick up 3mph in my traps to match
Nice times.
Old Nov 27, 2008 | 02:06 PM
  #43
BoostedBeaner's Avatar
very nice times. i went to the track the same day down here in florida
Old Nov 27, 2008 | 02:16 PM
  #44
drew1991sf's Avatar
my first time at the track i did a 15.00@100.52mph
and ppl who do 14's have the same trap shouldnt theres be higher or mine be lower
Old Nov 27, 2008 | 02:19 PM
  #45
cakeeater's Avatar
not necessarily. what were your 60' times like? 1/8 mile?
Old Nov 27, 2008 | 02:21 PM
  #46
drew1991sf's Avatar
2.5
and 660' 10.054@77mph
Old Nov 27, 2008 | 02:23 PM
  #47
cakeeater's Avatar
well no offense but your 60' is horrid. generally more spinning off the line will lead to a higher trap speed, but a lower E.T. but i like i said this isn't always the case. If you spin enough or at the right times, or if you are geared a certain way, spinning may not effect the trap speed or even make it lower. In your case it probably kept it about what it would ahve been with like....a 2.0-2.1 60'. it might actually be higher with one of those 60's depending on how you drove.
Old Nov 27, 2008 | 02:28 PM
  #48
drew1991sf's Avatar
LOL ya ik it was bad but it was my first time and i am plannin on goin on sunday to redeem myself :]
Old Nov 29, 2008 | 07:28 PM
  #49
zrated89's Avatar
practice youll be better im only at 275ishwhp and i ran a 13.3 @109 good times tho
Old Nov 29, 2008 | 07:40 PM
  #50
AROON02's Avatar
wow talk about a reaction time lol keep tryin nice though 300hp car running a 13.5
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Sep 27, 2015 08:53 PM
roth
Sep 26, 2015 12:16 PM
