3rd gear shattered. Yes another one.
Old Mar 23, 2014 | 03:47 PM
  #76
Powell Race Parts's Avatar
Originally Posted by Wert842
What do you need explained? Its first through fifth gear with the rpm and mph range. Gears are accordingly put first through fifth left to right.
Ex. Fifth gear at 70mph in a 4.05 is approx 3k rpms.
exactly. Princess think it through, print it out/ take a ruler and a pencil. go to your max rev line, then go from first gear trace horizontally down to the second gear trace; draw a line. thats your rev drop when you shift. You can see how you might want to short shift or over rev before shifting depending on the application and the torque curve of the engine. Ideally you want to keep between peak power and peak torque . In real race cars you can change ratio's to satisfy that. The excel spreadsheet I use allows for histograms so we can plot engine power curves and make life easier figuring things out.
SAAB 5 speed F35 style trans has a longer 5th gear than a Cobalt FYI. So if you cared about revs on the highway and only auto x'd or short tracked you could do that ration change and drop a hundred or two revs in top for cruising.
Not sure I care to go through the effort to build that, GM dont sell fifth gears new, and the supply of used gears is finite...same for the SAAB F40 they dont make that trans anymore
Old Mar 23, 2014 | 03:52 PM
  #77
Cobe's Avatar
Hey Powell do you have any clue when the 4.45's will be available again? Sorry to thread jack. Just wondering so I can start saving. Id be nice to have my tranny still good and not blown! and sell it and get some money for it to put towards the 4.45 LSD lol
Old Mar 23, 2014 | 03:59 PM
  #78
we got 4.45 not a problem today but I get a half dozen requests a week so the sad fact is folks with money get them first. It looks like based on the data I am seeing, I will only put treated gears in trans anymore, so that means we will not build any without treating the gears and the case looks like. The risk of selectively heat/chill/shotpeen treating parts is that if you make only one part strong you make the untreated parts weak by comparison.
Pricing of our entire trans program is currently on hold as of yesterday, while we review what we are doing/going to do/what it costs to do it. I am not saying that the price will go up/ at all/or astronomically, but I am saying that if we are too expensive for folks they should really go and find another place to build their transmissions.
Also the issue of core transmissions is big. We have a lot of unuseable cores. A new bellhousing ( that gets broken when gear fragments get trapped in the bearing pocket) is 700 dollars plus shipping. USD for our canadian customers, which is a 14% increase due to exchange fluctuation.
Old Mar 23, 2014 | 04:03 PM
  #79
taintedred07's Avatar
Lol at the DMF. I hate the things, soooo heavy and difficult to deal with. I will take clutch chatter and gear rattle over a DMF. At the end of the day folks will do what they wish, and anyone who springs for an F40 is hardly going to say they made a mistake....FYI the SAAB F40 guys ditch the DMF ASAP when doing a clutch change
Yea but wouldn't the dmf be ideal for the turbo rather than the fidanza?
Old Mar 23, 2014 | 04:06 PM
  #80
Cobe's Avatar
So that being said you should and are going to start treating all internals in the transmission?
and you saying we got 4.45 not a problem today means you have them in stock? If so I will PM for pricing once you have figured out your transmission program. I also do not plan on getting a trans from anywhere else .
Old Mar 23, 2014 | 04:10 PM
  #81
a flywheel that is over double the weight of a stock flywheel is not a good thing regardless of what induction system used imho. I dont care what people do, its just shockingly funny to see the folks with stock DMF bail on them asap ( that was the first thing we did on the cadillac ctsv race cars we built in 2004) and here there are a bunch of folks (lemmings maybe) all drinking the DMF koolaid...i guess it goes with a K&N ?
Old Mar 23, 2014 | 04:25 PM
  #82
Lmao
Have you had any turbo swapped high hp/tq cobalts test the 4.45 yet that you know of?
Old Mar 23, 2014 | 04:27 PM
  #83
Lmao
Matt Nanos ( Raver 6789) and ZZP both come to mind. ZZP then went auto.
Old Mar 23, 2014 | 04:31 PM
  #84
Well I meant built by you, I remember you talking about the zzp 4.45 shortcomings from their trans connections. I've only heard of a couple zzp 4.45's breaking, most of the big turbo guys have the 6speed. I have your 4.45 along with the gmpp and I'm going to be around 600+whp/wtq soooo I guess I'll let you know haha
Old Mar 23, 2014 | 04:34 PM
  #85
right. driver mod protects clutch and trans. thats the most significant thing.
Old Mar 23, 2014 | 04:37 PM
  #86
That's what I'm rooting for.
Old Mar 23, 2014 | 04:44 PM
  #87
raver0789's Avatar
You have a boost controller I thought you said. You can always change boost on the fly, much like I do. Usually for street I have my A/B setting at 24psi/26psi. As long as you aren't daily driving 600whp/500lb feet and on it every day, you should be fine.
Plus...there is only so much power you can throw at these platforms on the street without slicks. 500whp is insane. 550 would be too much. 600? Overkill. You will never get the power down.
Old Mar 23, 2014 | 04:53 PM
  #88
Originally Posted by raver0789
You have a boost controller I thought you said. You can always change boost on the fly, much like I do. Usually for street I have my A/B setting at 24psi/26psi. As long as you aren't daily driving 600whp/500lb feet and on it every day, you should be fine. You can always select another boost setting if you track it - or you run into something you need to beat that is so worth going to jail over.
^^^ this. Lol@" or you run into something you need to beat that is so worth going to jail over."
  #89
Yea, I was getting bored with the zfr at 25psi on e, assuming I was low 400's. I have no idea what 500+whp would feel like, but the way I see it is I got everything built for a reason. But of course, traction and what not in the street is always going to be an issue. But scythe was around 600whp in the street and I know there's others.
But yea, I have a mbc so I won't be dding it at that power level lol
Ahhh, can't wait!
Old Mar 23, 2014 | 08:09 PM
  #90
63 Nova SS's Avatar
John, let us all know what the prices will be when you get it finalized.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
