400whp with zfr?
Old Oct 30, 2013 | 09:16 AM
  #176
armcclure's Avatar
I think very few are because of the horror stories created by poor installations. That and they're scared it'll eat the coating off their roto.... Oh wait.... Nvm.
Old Oct 30, 2013 | 09:32 AM
  #177
Powell Race Parts's Avatar
Ya Cory I sure would run a fogger pre compressor based on the information and articles from very good sources Alan has found; killerbee, cosworth and someone else I forget lol....already. Let Alan do the spade work for you.
there are three things; 1 the science, and this so far is well backed up by Alan with the information so far .
then 2. there is manufacture and installation of the parts ( simple nozzles are not the best atomisers)
then 3. there is the field testing tuning and development - cant be beat for actually proving the theory and the parts.
So I am thinking: where are the similar three things to back up meth injection into the IM or charge tubesm post compressor on turbos?
Old Oct 30, 2013 | 12:13 PM
  #178
Matt M's Avatar
Perhaps the single greatest article I've found yet... It'll take you about a half hour to read, but it's 100% worth it!
CHEMICAL COOLING Ť Killerbee Performance Technologies
Should add that is is an advertisement disguised as an article. Also, he's very bad at math and throws a lot of theoretical concepts out there as sure fact.
Old Oct 30, 2013 | 12:51 PM
  #179
Good point. Maybe alan can send you the cosworth info etc. Cosworth are well respected world wide and prolly don't screw up the math.
Old Oct 30, 2013 | 01:08 PM
  #180
Matt M's Avatar
Yeah, I'm not saying it can't be beneficial, but this advertisement significantly overstates the gains for most practical purposes.
Old Oct 30, 2013 | 01:11 PM
  #181
armcclure's Avatar
Not argueing that. But that doesn't mean he's not right on when it comes to the how and why.
Here's the cosworth article. As John said, very few people would try to declare their concepts and results as fictions.
http://www.lolachampcar.com/pci_ring_fueling.htm
ps: I think you guys would be pleasantly surprised of you relocated your 5th injector setup to run PCI... What's it hurt to try?
Old Oct 30, 2013 | 01:25 PM
  #182
Matt M's Avatar
PCI Ring Fueling
That page is more of the same, though. It points out how the charge temp starts dropping under load because the ring is spraying. However, the same thing happens on all supercharged LSJs and all LNFs with an aluminum lower charge tube. With very little air flowing through the intake manifold or lower charge tube, it tends to soak up engine heat and show high iats. Once airflow is increased, the temps naturally drop, without spraying anything in the turbo or blower inlet.
Old Oct 30, 2013 | 01:30 PM
  #183
armcclure's Avatar
To below ambient?
Old Oct 30, 2013 | 03:29 PM
  #184
Matt M's Avatar
To below ambient?
I'm skeptical of that data. There are too many variables that can affect the accuracy of those readings.
Old Oct 30, 2013 | 04:09 PM
  #185
armcclure's Avatar
They were only running about 10psi. Makes things alot easier.
Bottom line, I don't understand your resistance to the subject. This whole thread is about pushing a zfr farther.
It's non refutable that PCI increases compressor efficiency.
Have you guys tried any firm of PCI? Surely you have some old k04's you could slap on a car some evening ang give it a whirl. What is there to lose other than a few hours of your time?
I know you're a smart guy and I respect you. I guess I'm just saying if you don't want to give merit to the possibility then fine. But at the very least, explain why.
Old Oct 30, 2013 | 04:21 PM
  #186
Matt M's Avatar
I'm not resisting the subject. I'm resisting the all too common phenomenon that repeats itself in every market where people start acting like water injection is magic and makes big power gains. Then absolutley no one in that particular market runs it successfully. Then it repeats in the next market exactly the same. Does this mean there are no gains to be had? No. My point is that the gains will be minimal at best.
Old Oct 30, 2013 | 05:49 PM
  #187
armcclure's Avatar
Meh. Ill take what I can get. Looks like I've got some work to do.
One thing ill add though: has ANYONE here tested a proper PCI setup? Not that I've ever seen.
And Matt, have you guys even experimented with it on an lnf or lsj-t?
Old Nov 8, 2013 | 12:13 PM
  #188
r3v07ut10n's Avatar
Going all out, 3gph pre compressor, 3gph direct port, spraying 75% meth.
Going to get my tuner to dyno with just the 4 spraying then hook up the pre comp and dyno then again to see the results.
Man cant wait until spring
Old Nov 8, 2013 | 12:28 PM
  #189
armcclure's Avatar
So 5 3gph nozzles total?
Old Nov 8, 2013 | 12:34 PM
  #190
r3v07ut10n's Avatar
Yup.. 5 - 15gph total. If it blows... ill rebuild. but the key is to tune the 4 port first, then retune for the pre comp to see the differences. If it isnt a big gain etc... I believe i should be fine. if the differences are minimal then i will remove the pre-comp nozzle.
Old Nov 8, 2013 | 12:53 PM
  #191
armcclure's Avatar
How are you orienting the PCI nozzle?
Old Nov 8, 2013 | 02:15 PM
  #192
r3v07ut10n's Avatar
~5" away most likely top oriented. From my discussion with Rodney AIS, it really doesnt matter since the air flow is so great at that point. He did mention that i shoudl start hitting around 16psi though.
Old Nov 8, 2013 | 03:56 PM
  #193
armcclure's Avatar
Yeah, don't want it coming in till you're nearing 65ish% of peak boost.
Old Nov 8, 2013 | 04:51 PM
  #194
r3v07ut10n's Avatar
ive read quite a bit about spraying directly at the turbine, but id have to make a bracket up to hold it etc. I read some good stuff on aquamist forums and a few MS3/6 forums seeing so decent results.
Old Nov 10, 2013 | 03:13 AM
  #195
Fastgti69's Avatar
If you have an intake it would be easy to drill into that and tap a meth bung.
Old Nov 10, 2013 | 11:59 AM
  #196
r3v07ut10n's Avatar
thats the plan, I HAD a hahn CAI, but just bought a K&N SRI.
Old Nov 10, 2013 | 01:48 PM
  #197
Fastgti69's Avatar
Sweet
Old Nov 10, 2013 | 09:13 PM
  #198
Matt M's Avatar
Did you mean compressor? I don't see anything good coming from spraying meth on the turbine wheel.
Old Nov 11, 2013 | 07:44 AM
  #199
r3v07ut10n's Avatar
^ Yes, that is what i meant.
Old Nov 11, 2013 | 08:53 AM
  #200
I think a fogging ring in front of the turbo impeller would be okay. But I dont use meth anymore. Pita deal.
