400whp with zfr?
Old Nov 11, 2013 | 09:12 AM
  #201
r3v07ut10n's Avatar
Fogging ring.... custom made?
Old Nov 11, 2013 | 10:06 AM
  #202
Powell Race Parts's Avatar
Arm will make one. let me post a link to a place that makes them for trucks. haha I googled "meth fogging rings for truck engines"
got this:
Recent Drug Bust Stories | abc30.com
Old Nov 11, 2013 | 10:21 AM
  #203
CHEMICAL COOLING Ť Killerbee Performance Technologies
here ya go. Bear in mind that Matt M@ZZP and myself are not fans of meth injection. I have used it extensively in the past on my s/c engine. Cory you are prepared to experiment and if it doesnt work your eyes are open and you will stand up and pay for an engine with no whining. Well maybe a little....
Arm is determined to do it and can make parts as he is an excellent machinist with access to CNC equipment. So you two should pool resources. Cheers.
Old Nov 11, 2013 | 11:51 AM
  #204
raver0789's Avatar
Cory I like your setup. But I wouldn't spray pre turbo. The enemy is not the heat. The iat2s on your logs are low. The turbo is still mostly efficient. Not at a point where I would say it could be the source of detonation where you need to cool it...aka stock turbo. On your last setup you held only 18 degrees of timing. When you increase timing when tuning boost typically drops. That is why i think your 4 nozzles will be better and enough. To hit 500 who I had to run 25 degrees of timing. Big difference. We want to hit 23ish at least on yours. And why 75% meth? You are already at a point where it is flammable so why not 100%?
Old Nov 11, 2013 | 12:04 PM
  #205
raver0789's Avatar
It's just your previous setting wasn't providing much octane improvement over pump gas. I think this new setup will. But I wouldn't risk damaging your turbo.
I think with more meth and 29psi you'll be very happy.
Old Nov 11, 2013 | 01:15 PM
  #206
armcclure's Avatar
Increasing compressor efficiency, at any point, gives you more airflow at the same or lower boost. That in itself is a win/win situation.
3gph pre comp is small enough that no damage will be done until WAY down the road, that's been tested over and over.
Those killerbee foggers are nice but not much option in jetting.
I've been working on a few different designs, made part of one on lunch break today.
Ill keep you guys updated.
Old Nov 11, 2013 | 02:40 PM
  #207
r3v07ut10n's Avatar
Keep me posted, i am in for this! I didnt want to go smaller than 3gph because then it becomes crazy small and very easy to clog- requiring cleaning every 2-4 weeks.
Old Nov 12, 2013 | 07:24 AM
  #208
r3v07ut10n's Avatar
Lol John, i wouldn't whine, id be just pissed that is all, but then id be happy for new build. I should be fine though i recon. Im more worried about the chain getting eating up. I believe the culprit is that tensioner. I may just change that thing every year or 2 as it is a cheap item.
Hoping i get this house i am about to bid on, has a 30x40 garage with a car hoist
KillerBee... guy has alot of bad rep on the duramax forums.
Old Nov 12, 2013 | 08:59 AM
  #209
armcclure's Avatar
I change mine every 10k.
Had 3 in the last 5k. Once I started changing them frequently, problems went away. I also went to arp m8's on the black guide and an arp m6 on the tensioner arm though.
Old Nov 12, 2013 | 09:02 AM
  #210
good luck with the house, major good step and a HOIST??!!!! Primo!
Old Nov 12, 2013 | 09:08 AM
  #211
r3v07ut10n's Avatar
I got the arp studs from john when i did the full timing kit when i installed my valves.
Best of all John, its 2km from my work.
Old Nov 12, 2013 | 09:27 AM
  #212
AaronJ's Avatar
So did we ever get an answer on that, is 400 whp doable with the ZFR without an E-blend or meth?
Old Nov 12, 2013 | 09:39 AM
  #213
r3v07ut10n's Avatar
http://i803.photobucket.com/albums/y...psbd23c2a9.jpg
CA did with cut out open.
Old Nov 12, 2013 | 12:56 PM
  #214
C_A_D88's Avatar
Yes I hit 403whp with open cutout precat. Probably not needed with 3" straight pipe, but I've got a cat a res and twin 2.25" pipes axle back
Old Nov 12, 2013 | 04:38 PM
  #215
willdrew's Avatar
Awesome and on 25psi not bad at all
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
Shane H
Sep 20, 2015 11:56 AM
jcalvin1126
Sep 11, 2015 10:24 AM
