Aeromotive Fuel pump
Old Apr 14, 2012 | 02:08 PM
gone_in_10_sec's Avatar
Installing the ZZP/Aeromotive fuel pump:
I finished installing it but she's not turning over.. got a 1/4 tank in the tank.. i used the existing in-tank plug.. but didnt used the aeromotive plug since the OEM plug fit right in..
Old Apr 14, 2012 | 02:18 PM
nhanson's Avatar
Check power to the pump?
Air in the lines?
Pull the injectors and see if they spray?
Old Apr 14, 2012 | 02:30 PM
FasterIsBetter's Avatar
A no on pulling the injectors. He'd have to replace the seals. Just check your fuel pressure at the fuel pressure check valve under the hood.
Old Apr 14, 2012 | 02:32 PM
Also check and make sure you didn't put the electrical connector for the fuel pump in backwards.
Old Apr 14, 2012 | 02:37 PM
is the aeromotive fuel plug and the oem fuel plug the same polarity?
Old Apr 14, 2012 | 02:50 PM
cmiller8006's Avatar
I had the same issue. Unfortunately you will have to drop the tank and reverse polarity on the pump. Yes the plug fits right in but the positive and negative are switched on the pump compared to what the stock plug is. Basically the pumps spinning backwards. You can here the pump tho right?
Old Apr 14, 2012 | 03:04 PM
Yeah, thats what I thought. A lot of aftermarket fuel pumps have reversed polarity connectors. OP could either splice it or pull the stock connector apart and switch the polarity inside the plug.
Old Apr 14, 2012 | 03:09 PM
i pulled the tank again. just realized I reversed the polarity.. duh..
Old Apr 14, 2012 | 08:24 PM
Since I had a brain fart today.. I want to thanks the guys for helping out!! She runs like a champ now.. thanks guys!!
If anyone swaps there LPFP, don't forget to check the polarity on the new fuel pump with the old fuel pump before you install the pump back into the tank.. for a min there i really thought i was losing my mind..
Old Apr 15, 2012 | 12:14 PM
nhanson's Avatar
Oh this is LNF thread...haha
Old Apr 15, 2012 | 02:45 PM
Matt M's Avatar
That's what I thought when we were troubleshooting CMiller's install. I had even sent him a pic with the polarity reversed on the plug compared to his pump. I couldn't figure how mine was working correctly since I never switched the wires.
We pulled my pump the other day for a new custom setup, and this is what I found...
Both of these pumps are the same part number:
Old Apr 15, 2012 | 05:58 PM
FF_ace's Avatar
Whats the part number on these?
Old Apr 15, 2012 | 09:38 PM
Matt M's Avatar
I think it's 11140.
Old Apr 15, 2012 | 10:00 PM
Yep it appears aeromotive likes to be little trixters lol.
Old Apr 16, 2012 | 12:17 AM
SSlobalt's Avatar
Well I'll be dipped in ****. Those bastards.
Old Apr 16, 2012 | 12:47 AM
Sox-Fan's Avatar
Got Brakes?
I can only imagine the level of frustration that comes with doing customer support when your suppliers/vendors make significant changes like that with no notice and no part number change.
Matt, is your hair grey?
Should have seen me that day. I was so dumb founded that I could here the pump run and there was no f'ing fuel lol. Then when I got ahold of Matt here did some searching and found the different polarity deal. By that time I had already had the tank down, only problem was of coarse I had filled it full.
Old Apr 16, 2012 | 09:33 AM
Matt M's Avatar
Yes, that makes it difficult at times. It's bad enough trying to keep track of our own product changes.
Old Apr 16, 2012 | 11:24 PM
hey matt -
i prob got more grey hair than you after installing fuel pump last saturday.. hehe...
anyway is that custom pump setup.. is it the dual fuel pump setup for the LNF? just sayin??
Old Apr 17, 2012 | 01:06 AM
JBThrasher22's Avatar
hey matt -
I believe he was just showing two exact matching part # fuel pumps side by side with different polarity markings on each pump for reference since his was set up same as stock when he installed his hence why he never had to switch the polarity. I could be wrong though.
Old Apr 17, 2012 | 01:10 AM
I know Matt was showing the polarity on the pump, but I asking about what he stated in the past about testing dual LPFP for the LNF.. I remember late last year Matt was talking about something to this effect..
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
