ahh code p0236 help
Old Aug 1, 2010 | 02:32 PM
ripped's Avatar
ahh code p0236 help
ok guys im ready to pull my hair out.
heres the deal friday installed tmap sensor uploaded new trifecta tune to run more boost. car ran fine for a hour data logged everything looked good.
car went into limp mode started to pour ran codes. p0236 ok so its the sensor and nothing more
sat- redid wires spliced again but soldered this time to make sure they where done real good heat wrapped. reset ecu. car ran fine data logged again. everything fine but now no boost gauge. gauge comes back on later. couple hours later limp mode fudge. checked wires disconnected. hours later limp mode same code.
sun. disconnected batter but boost guage working this time upon startup. i know the ecu will make the car go into limp mode later.
im pointing towards i was sent a faulty sensor or connector to sensor is faulty.
im just wondering what you guys think since obviously
1. we connected the wires right other wise the sensor wouldnt work at all nor would we b able to data log.
2. im curious as to why the sensor would work for a while then bust out.
3. like i said im pointed towards the sensor or the connector is faulty i cant order new parts till monday.
your guys input and help is appreciated.
is there any way to check to tell if the sensor is faulty or the connector like things to look for
Old Aug 1, 2010 | 03:05 PM
09BlueBaltSS's Avatar
When is it going into limp mode? Just driving or at wot? How much boost u trying to run now?
Old Aug 1, 2010 | 03:23 PM
ripped's Avatar
goes into limp mode after the ecu figures out the sensor is the problem dosnt matter what mode. boost is anywhere from 24-28
Old Aug 1, 2010 | 03:42 PM
On stock turbo? Your gonna end up like Fabian
Old Aug 1, 2010 | 04:21 PM
ripped's Avatar
lol why what he do
Old Aug 1, 2010 | 04:31 PM
Cracked a ring land. Reguardless of what sensors you have thats just too much for that turbo. Either the turbo or a ring land is gonna give eventually
Old Aug 1, 2010 | 04:45 PM
tomj77's Avatar
ya dude u obviously dont read the threads on here about people busting ringlands, always happens to guys running over 24psi. ur turbo wasnt ment to boost that high, so id stop before it costs u a ton of money if i was u.
Old Aug 1, 2010 | 05:54 PM
ripped's Avatar
ill lower the boost back down as soon as i can get the dam sensor to work properly worse comes to worse ill go back to the 2 bar sensor
Old Aug 1, 2010 | 06:01 PM
RiceCop's Avatar
He has been doing all this with me, we actually lowered the boost some to make sure he's safe. He is running 24psi in 4th, 1-3 he is at 23psi. 1st log he did spike 28psi in 4th and vince backed it down to make sure he doesn't blow the motor. This sensor thing is crazy, it works fine for a while and then just goes into limp mode.
Old Aug 27, 2010 | 05:34 PM
raver0789's Avatar
Sorry, any new news on this thread?
What did you do to fix the p0236?
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
