Almost got the head loose!
Old Feb 10, 2013 | 03:50 PM
etnies's Avatar
Ok so i spent all day yesterday taking out the complete turbo system and getting the head off the car. I'm down to unbolting the head and pulling it. The intake and exhaust r still attached but I figure it will give me a better handle on removing the head. Only reason I stopped last night is there is one torx or Allen bolt bolt on the block that you takeout to remove the top bolt in the intake side cam chain guide and I didn't have the correct size torx bit. Anyone know what size it is? I'm thinking at least a 60 or 65
Sent from my iPhone using CobaltSS
Old Feb 10, 2013 | 04:13 PM
cmiller8006's Avatar
Unless you take out the chain guides you wont be able to get the head off. Or unbolt the engine mount, and front tranny mount and use a jack to lower the front of the motor. I am not sure what torx bit you are talking about. There are four reverse torx on the timing side and ten head bolts. There is a support bracket that runs from the motor to the intake mani, but thats a 13 mm bolt. You have a pic?
Old Feb 10, 2013 | 05:23 PM
etnies's Avatar
Even if I had a pic I couldn't post it photo bucket went fubar on me last week and I still can't upload. All I was needing was the access port Allen size so I can remove the chain guide bolt at the top and move it to get to the last hex bolt like you we're talking about and thanks for the info on the bracket runnin to the block
Old Feb 10, 2013 | 05:25 PM
etnies's Avatar
I ment reverse torx bolt not hex sorry
Old Feb 10, 2013 | 05:36 PM
Omiotek's Avatar
its like e10 or e12 i cant remember off hand what it is.
Old Feb 10, 2013 | 06:09 PM
The alen head is a 10 I am pretty sure. Pretty hard to get out
Old Feb 10, 2013 | 06:21 PM
etnies's Avatar
Nice now I'm gonna go to Walmart since they are the only place open this late on Sunday and attempt to find an e10 Allen or at least a torx that will fit it
Old Feb 10, 2013 | 06:41 PM
etnies's Avatar
On a side note I am selling a full stock turbo setup all the way from manifold to dp including the k04 I don't care to part it out either if anyone is interested
Old Feb 10, 2013 | 09:07 PM
Also a six point 3/8 will work on those reverse torx. Thats what I use.
Old Feb 10, 2013 | 11:41 PM
etnies's Avatar
yea I used a e12 on the outer most two and couldnt fit it on the inner ones so i used a 3/8
and the access port was a 60 torx bit btw
Old Feb 10, 2013 | 11:54 PM
etnies's Avatar
everything looks decent but the 4th cylinder is glazed over bad, the head doesnt look like a valve is warped but im not the expert and the other cylinders look good and still have a decent cross hatch for 18k miles so i figured maybe serious ring failure is the culprit of no compression....and by the way cmiller i found another way to upload pics!
Old Feb 11, 2013 | 01:55 AM
Nfamous60's Avatar
not bad gotta do my head next week to replace gasket and install valve springs and cam.
Old Feb 11, 2013 | 02:31 AM
etnies's Avatar
its not my best memory that I can share with this car lmao but Its another step towards having a safe 430-450whp cobalt so im pleased! lol
Solaris99
28
Mar 15, 2017 01:22 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 28, 2015 12:51 PM
