Another LNF missing an injector seal.
Old Feb 6, 2012 | 01:18 AM
  #101
FasterIsBetter's Avatar
Originally Posted by Chevycobaltss3
Lol no, I have my ways....
Lol, made something to press the seal on eh? or used the head somehow...
Old Feb 6, 2012 | 08:25 AM
  #102
Chevycobaltss3's Avatar
Lol, used the head..... (Heat gun so it flexed better, brake cleaner to cool and shrink the seal, along with my fingers... It worked just as good.
Old Feb 6, 2012 | 08:39 AM
  #103
cubaniche's Avatar
Nice! As long as it worked
Old Feb 6, 2012 | 08:41 AM
  #104
Yea, it worked great lol.. seals didn't have movement or warpage..
Old Feb 6, 2012 | 10:10 AM
  #105
Well, youll be getting the tool and seals today.
Old Feb 6, 2012 | 10:18 AM
  #106
Saweeeeeeeeeeet lol... I told you is lend you my car so I can do ures lol.. just letting you know i really would lol.
Old Feb 6, 2012 | 10:21 AM
  #107
Lol, its cool. I might be able to do it at my buddys garage this weekend if the big rig isn't down. Last weekend he had to rewire headlights.
Old Feb 6, 2012 | 10:23 AM
  #108
******... Sweeeeeet
Old Feb 6, 2012 | 10:26 AM
  #109
And as I said before, just help me with questions about the install and the tune, lol. I ordered that wastegate spring so you could tune it easier. I may ask a few questions about the vac line routing but everything else should be straight forward.
Old Feb 6, 2012 | 10:27 AM
  #110
Ok lol.. good dealio..
Old Mar 5, 2012 | 10:13 PM
  #111
overboostedss's Avatar
dont meen to be stupid but where can I get the upgraded seals?
Old Mar 5, 2012 | 10:16 PM
  #112
Gm itself or call up crate engine depot.
Old Mar 5, 2012 | 10:22 PM
  #113
Yeap, or get the part number and order them from GMPartsEast.com like I did. They ship out quicker than anyone else if you live on the east coast.
Old Apr 8, 2012 | 09:42 PM
  #114
Kbbalt's Avatar
Any part number on this?
Old Apr 8, 2012 | 10:10 PM
  #115
12633374 is the part number
Old Apr 9, 2012 | 10:32 PM
  #116
Friday-Smasher's Avatar
What else are some of the symptoms of injector seal failing? I don't have any gunshot noise going on but my cold start(cat warm up mode) been going crazy. In very cold morning's it used to miss and idle so rough that it would throw misfire CEL's all the time, then once it come out of the cat warm up mode things would be back to normal and fine. The weather around here been warm and my cat warm up mode been better and no CEL but it's still very rough.
Anyone know what this could be? or is this something you guys also notice with injector seal failing?
Old Apr 9, 2012 | 10:56 PM
  #117
Check your charge piping and your intake. You most likely have a cut coupler, a hole in the pipe and your fuel trims are all jacked, or your intake could have fell out of the neck to the turbo after the mass air flow sensor. And if you still build boost you can still have a leak. That doesn't mean anything other than the leak isn't bad enough that your turbo can't keep up with the volumetric losses. I could still boost to 23psi no problem with a 3/4" gash in one of my couplers and had to replace it.
Old Apr 9, 2012 | 11:33 PM
  #118
checked everything and can't seem to find anything out of place. My LTFT is fine where it's suppose to be and where it's been. I checked coils, plugs, and even did a compression test and everything is normal. Only thing I didn't do is check my injectors, but I'm just not 100% that it could be injectors since the rough idle only happens during cat warm up start and I have no popping noise or anything like that. however, when the weather was cold I can hear what sound like static or rattlesnake type sound mixed with hissing only during load. I believe that noise is from my catless pipe tho.. After that everything is fine. No issues at all. I just can't seem to figure out why my cat warm up mode all of a sudden went crazy. I can somewhat deal with it now since the weather is warm and I am not getting anymore misfire CEL but the cat warm up idle is still very rough. I am lost. LOL.
Old Apr 10, 2012 | 12:23 AM
  #119
I would try a purge valve solenoid then. They're cheap and go bad often, especially when tuned.
Old Jun 2, 2012 | 01:42 PM
  #120
hunter19707's Avatar
Mine is at the dealer getting an injector replaced due to missing seal. It sounded almost like gunfire when accelerating. I hope they check the other injectors, I'll find out Monday.
Old Jun 2, 2012 | 07:24 PM
  #121
Maven's Avatar
Unless your dealer tech is a complete tool theyll replace all the seals, its actually required by GM to replace all the seals, o-rings and retainers any time the fuel rails or any injector is pulled out.
Old Jun 2, 2012 | 09:42 PM
  #122
Iam Broke's Avatar
^^^^ I believe the rail fuel feed line also although I reused mine. I still have a spare though that was delivered too late.
Old Jun 2, 2012 | 09:56 PM
  #123
Maven's Avatar
yes, both hard lines as well. They are round ball seats, an are only esigne to seal properly once. I know that EVERYONE has reused them.....
Old Jun 5, 2012 | 03:26 PM
  #124
ramrod1337's Avatar
Originally Posted by Iam Broke
Good info... don't forget the intake mani gasket too while you are at it guys.
Is this more of a suggestion? or a better ******* do it?
Old Jun 5, 2012 | 08:16 PM
  #125
Engineer was called in, I would like to think they did all of the seals. Engineer had them remove the head and clean out the carbon deposits as well.
