Bad rattle/knock on driver's side...
Old Oct 5, 2009 | 02:47 PM
Rissa's Avatar
Yeah mine is definitely somewhere in the door.
Old Oct 5, 2009 | 02:55 PM
Terminator2's Avatar
It is probably the striker or the mounting tabs for the door panel.
Old Oct 5, 2009 | 06:28 PM
Cpott's Avatar
you think your cars rattle? mine rattles squeaks and hummmms never blast 2 subs in a cobalt...your **** will fall apart
Old Oct 5, 2009 | 09:40 PM
MaxVQ35DE's Avatar
when i listen to bass heavy music, my outer door handle rattles like a hoopdie license plate.... really pisses me off, but not as much as the steering column and rear seat rattle
Old Oct 5, 2009 | 09:44 PM
68nova200's Avatar
probably the control arm bushing. happened to me twice, one on each side.
Old Oct 6, 2009 | 09:56 AM
80vetteL82's Avatar
My rattle sounds like it's coming from inside the driver's side door.
Yah mine does too. I actually took the door apart about a month ago and checked to see if there was anything in there but there was nothing. I also dynamated the car, including the driver's door...it helped with road noise, but the rattle is still there.
I think the latch on the door that hooks onto the jamb striker maybe loose. I can wiggle it back and forth...
Old Oct 6, 2009 | 10:18 AM
BlueStang's Avatar
you know what they say something small left un checked turns into something big
Old Oct 6, 2009 | 05:44 PM
rukkee's Avatar
Well i WD40'ed my passenger striker and the sound was still there initially.....so i figured oh well , i better try something else.............But today it completely stopped ?? I'm very surprised ....It (wd40) must have worked its way into the area that was causing the squeak . I'm amazed because some of the roads i hit today were terrible and would have drove me crazy if the door was still squawking.
Old Oct 6, 2009 | 08:17 PM
80vetteL82's Avatar
This is more of a knocking/clicking, than a squeak.
Old Oct 7, 2009 | 12:52 AM
rukkee's Avatar
I see, mine sounds like the door isn't shut all the way . It used to thump and squeak and rattle and knocked lol, a little of everything. The weather cooling down up here may be helping my situation as well.
Old Oct 7, 2009 | 09:49 AM
  #36
BlueStang's Avatar
yep WD 40 & duct tapes all you need to fix a cobalt
Old Oct 7, 2009 | 10:06 AM
  #37
Double sided sticky tape is your friend.
Old Oct 7, 2009 | 10:10 AM
  #38
Sweetsandman's Avatar
Mine makes a weird noise right by the door jam on the driver's door but ONLY if I have my window cracked open a little...like 1 inch or less...doesn't do it if it's closed..or if it's opened anything more than about an inch...freaking weird.
Old Sep 15, 2012 | 12:20 AM
  #39
Aleksey's Avatar
Has anyone found a fix for this? I'm experiencing the same exact issue as OP and it's beyond annoying.
Old Sep 15, 2012 | 02:02 AM
  #40
kzak104's Avatar
check the lever you pull to adjust the seat, thats where my rattle was when i thought it was coming from the door.
Old Sep 15, 2012 | 03:40 AM
  #41
Aleksey's Avatar
Not it, definitely sounds like it's coming from the door
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
