best ic between zzp, treadstone and mpx?
Reviving a dead thread!!! goin to install mpx ic this wkend will post pics and the mpx is direct replacement as well, and hangs jus above the lip not lower
I'm gunna see if can have a friend weld up bigger inlet/oulets for it too(not switch the end tanks, but if that nds to b done than so be it)
Treadstone TR8 intercooler on mah cobalt
intercooler layout
Conditions for driving
Comparison graph with IAT1 (intake air temp) and IAT2 (post intercooler air temp).
The days that these readings were taken were similar, baseline day may have been cooler by a few degrees which you can see in the difference between intake temps. Ambient temp was subtracted from the IAT temp so the numbers shown in the graph are the actual temperature difference between the IATs-Ambient.
intercooler layout
