Blown motor. Rebuild time
Old Jul 17, 2010 | 04:32 PM
fosterSS's Avatar
Well guys i just blew my motor up at 6000 miles. All my mods are on my sig. To be honest i think the played a big role in burning a hole through my piston and the rings ate the #1cylinder wall apart, but it was all worth it while it lasted. so im buliding from the ground up. I need some preferences on best pistons and rods. port the head or not port it.Thanks guys. ill get some pics up after i get out of this field excerise that im in.
Old Jul 17, 2010 | 04:39 PM
ItalianJoe1's Avatar
The tune killed it.
Weisco seems to be the popular choice for pistons. Are you goona sleeve the block or get another stock block? If you're staying stock block, I would suggest a different setup as opposed to a sleeved block.
Old Jul 17, 2010 | 04:44 PM
fosterSS's Avatar
sleeves
Originally Posted by ItalianJoe1
The tune killed it.
yea im pretty sure the tune did too, when i had it tuned i wanted the most aggressive tune vince could get me so it was my choice. the block is going to darton to get 4 new sleeves.
Old Jul 17, 2010 | 04:57 PM
conerboner's Avatar
good luck with the build... wanna see some pics...
good luck with the build... I wanna see some pics...
Last edited by conerboner; Jul 17, 2010 at 04:57 PM. Reason: Automerged Doublepost
Old Jul 17, 2010 | 07:26 PM
raver0789's Avatar
I want to know why the pistons aren't surviving....
Is it because of the amount of heat caused by the little k04 overspinning?
Or boost levels?
Will this be solved long term with a bigger turbo with more flow causing less heat?
Old Jul 17, 2010 | 07:36 PM
beast10007's Avatar
sucks dude but sounds like you where ready for it
any ways what size turbo are you going to use? Stock?
Old Jul 17, 2010 | 07:47 PM
fosterSS's Avatar
turbo
To be honest idk, I got a few ideas like the s256 or precisions sc62. It just depends how the motor build goes. If I get lazy I'm gonna just get zzp's kit and get it tuned.
Or boost levels?
its gotta be the heat issues. When I was runnin 28 lbs it wouldn't hold long . we are pushing the limits of this small turbo and finding out what the consequences are of doing so.
Old Jul 17, 2010 | 08:06 PM
ecotecturbo's Avatar
Another infiboost tune bites the dust.
Old Jul 17, 2010 | 08:34 PM
glhs379's Avatar
28 psi is too much on the little k04
did you data log your tune so vince could fine tune it?
Old Jul 17, 2010 | 08:43 PM
AcesNEights's Avatar
Ya im pretty sure i fried my piston rings in my car. 11k on it, ran 29psi for bout 2-3k. It sucks but at least the dealer is covering it!
Old Jul 17, 2010 | 08:48 PM
fosterSS's Avatar
tune
Yes the dealer that downloaded the tune on my pcm, prior to installing the tune we did 6 data logs. Under a load in like 5th gear at like 40 it would max out my boost gauge at 30 lbs
Old Jul 17, 2010 | 08:57 PM
Stamina's Avatar
That alone is not good for it.
Too far past 24psi or so, the rings are expanding to the point where the gap goes away and the ring's ends start pressing against each other until failure. The solution is to keep boost lower or gap the rings wider.
Wisecos have a much wider ring gap. This, in addition to them being forged, will allow for more boost, nitrous, and/or larger turbos.
Old Jul 17, 2010 | 10:17 PM
BYT*SS*TURBO's Avatar
Were you doing 5th gear pulls before it died? That seems to be the common thing with really high boost tunes failing!
Old Jul 17, 2010 | 10:21 PM
blackrocky's Avatar
show us some pics?????
Old Jul 17, 2010 | 10:30 PM
glhs379's Avatar
5th gear pulls on high boost=no good!
if you ain't won by the time you hit 5th, the race is over! lol
Old Jul 17, 2010 | 11:23 PM
raver0789's Avatar
Ok question....
Seeing how these pistons are frying with this infiboost tune...
Would the setup be somewhat reliable if you put in Wiseco LNF forged pistons and ran that tune?
I would think the pistons wouldn't go.
The turbo would eventually...
Old Jul 17, 2010 | 11:29 PM
Wangspeed's Avatar
Ok question....
The forged pistons would also break, just not as quickly. Maybe a few extra seconds
Old Jul 17, 2010 | 11:31 PM
RYRO14's Avatar
Ok question....
Yea it would probably be fine, but the turbo would say f you after awhile
Old Jul 18, 2010 | 12:19 AM
I would get a better turbo if your building the motor.
Old Jul 18, 2010 | 12:33 AM
Forged pistons are a ton stronger and would probably withstand the abuse, but the problem is trying to overspin the stock turbo and pushing it out of it's happy range. Leave it be at 23psi or get a bigger turbo.
Old Jul 18, 2010 | 12:38 AM
05Slowline's Avatar
Idiot lol
Old Jul 18, 2010 | 12:51 AM
fosterSS's Avatar
boost
no i wasnt doing 5th gear pulls. when the motor did give out i was at my stock tune .
i would be stupid to use the stock turbo after the motor is built. im deffinally going bigger. i wont be out of the field untill the 31 of july guys so sorry it will be a few weeks before i can get my pics up.
Old Jul 18, 2010 | 12:53 AM
05Slowline's Avatar
What I find disturbing is that this assclown is tuning so many people and runs 28psi on a stock lnf k04 car.
Now Im not anything close to a full blown tuner but I know what you can and cant do and if a customer would ask for that I would explain to them why I am not able to do that, not blow their ******* motor.
Such a joke.
Old Jul 18, 2010 | 02:23 AM
fosterSS's Avatar
tune
Such a joke.
I started out with the BSR/PPC from hahn and io wanted more. I did want a really aggressive tune i knew it would beat the motor up but, if i knew it would have been at 6000 miles on a car that i have owned since january of 09 i wouldnt have went that route. Thats one thing i will say there was no warning from the tuner or trifecta that it is possible just possible that your motor might self destruct. but on the same note us the customer want the baddest cars on the street. Its hard to say its really anyones fault at this point.
Old Jul 18, 2010 | 03:05 AM
05Slowline's Avatar
Yeah, but it's the tuners responsibility to say either say no or warn you you're getting to motor popping territory. Which he obv fails at doing. Like I said I wouldn't even give someone something like that just stupid.
