Boost issue
Old Apr 9, 2019 | 03:53 PM
n_hickman3's Avatar
Boost issue
After installing the ZZP fenderwell intake my boost is dropping off and not holding at 20 psi like it did with the stock airbox. Would this be something mechanical or something in the ECU?
Old Apr 9, 2019 | 08:07 PM
tomj77's Avatar
seeing as your supposed to tune for an intake, its probably that.
Old Apr 9, 2019 | 08:25 PM
63 Nova SS's Avatar
Are you tuned? It will flow better so if it's in a stock tune, it may not need to run as much psi to get the output out of the motor.
Old Apr 10, 2019 | 09:05 AM
n_hickman3's Avatar
yes I am tuned but the previous owner had it done so I’m not sure what exact tune it is.
Old Apr 10, 2019 | 09:07 AM
n_hickman3's Avatar
I figured it out, the coupler they sent me was either poorly made or had a defect because it runs fine with the stock coupler paired with the new pipe and filter. Holds boost where it should.
Old Apr 12, 2019 | 07:33 AM
tomj77's Avatar
So basically you were sucking in unmetered air and screwing up maf. Did ur engine light come on when it did that before?
DR.Feelgood
Mar 20, 2015 05:39 PM
michiganfootball911
Tuning
Nov 8, 2011 01:36 PM
Judder
Autocross and Road Racing
Jul 8, 2010 07:51 AM
tomj77
Dec 18, 2009 11:05 PM
crider4_6
Dec 2, 2009 08:45 AM
