Boost trouble...
Old May 2, 2011 | 12:43 PM
BPark86's Avatar
Boost trouble...
I have been having trouble off and on. I was getting the flutter and limp mode for awhile and it seems like the gas cap was actually to blame (it wasn't seating right). Months have gone by and now I am getting a pretty rough idle, hard start into first, nothing above 5psi in 2nd, and completely normal boosting (23psi) from 3rd on. Any ideas? You can see my mods below. I think the GMS1 MAP or TMAP is probably to blame. Took a look at the MAP yesterday and it did seem to have some particles on it that I cleaned. I'm going to have to remove some stuff before I can look at the TMAP. Definitely going to look into putting an oil catch can on. From what I can see so far there are no tears in the vacuum lines but I'm going to take a better look under the turbo tonight. **** pisses me off, always a problem...
Old May 2, 2011 | 12:45 PM
cranemaster's Avatar
I was having a similar problem last night, it went away when I stopped trying to no life shift..
I thought it might have to do with my car being stock, and having a catless dp... I was hoping GMS1, or any tune would stop the weird behavior since i put on the DP
Old May 2, 2011 | 12:48 PM
BPark86's Avatar
Mine will go away too... Just to come back absolutely randomly. Definitely not your dp, I have pretty much all things on my car and never had a problem until these last few months
Old May 2, 2011 | 12:55 PM
BPark86's Avatar
Now that I think about it... Maybe a bad o2 sensor in the downpipe. I'll have to check that later. Would those symptoms fit?
Old May 2, 2011 | 01:14 PM
Iam Broke's Avatar
A. Fuel trims whacked from the Hahn intake
2. A bad job on the GMS1 sensor install.
D. Possible boost leak.
Any CEL's?
Old May 2, 2011 | 01:53 PM
RyRidesMotox's Avatar
Any CEL's?
Winner... I bet they didn't solder the wires.
Old May 2, 2011 | 05:17 PM
BPark86's Avatar
There is a CEL that comes and goes, I need to get up to autozone while it is on. If it was the install, why would it be over a year before problems? When I turned the car on this afternoon it was backfiring BAD. I just let it do its thing for a couple of minutes and revved it up a few times. It feels like something is almost clogged or that I have bad gas? Suddenly it cleared, CEL went off, and no problems on the drive home. I'm sure it will be back soon, though..
Old May 2, 2011 | 06:19 PM
Iam Broke's Avatar
Bad crimp connections take time to corrode and cause problems. Solder, heat shrink & tape the connections. You can still get the codes read after the CEL goes out, they are stored in the ECU.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
