BOV spring upgrade
Old Jan 9, 2009 | 03:25 PM
  #126
cereal83's Avatar
Originally Posted by SSpdDmon
No worries...just make sure to put the filter back in after a few minutes of fun. Don't want ya suckin' anything up into that turbo.
lol I could throw some stones into the intake and see what happens.
Old Jan 19, 2009 | 03:13 PM
  #127
ericgt79's Avatar
ok im gonna order this
Old Jan 19, 2009 | 03:15 PM
  #128
Black08SSTC's Avatar
about damn time j/k
Old Jan 19, 2009 | 04:30 PM
  #129
Rissa's Avatar
I was just given one of these(Thanks HB SS/TC) is it worth putting on? It's chillin in my purse right now lol
Old Jan 19, 2009 | 05:08 PM
  #130
09silverSSS's Avatar
yes it is
Old Jan 19, 2009 | 05:14 PM
  #131
Rissa's Avatar
All right sweet! Wondering if I should attempt to do this myself lol.
Old Jan 19, 2009 | 05:20 PM
  #132
SUKXOST's Avatar
I've got mine sitting right in front of me. I re-read a few pages and could not find it but I saw somewhere that it does and will throw a CEL. Now I don't wanna put it in. Anyway around it with not upgrading the BOV? Will a tune be able to eliminate this or is it a mechanical fail so to speak and therefore never go away? Some intel from educated tuners appreciated please!
Old Jan 19, 2009 | 05:40 PM
  #133
it is very easy, 1)Take off the intake box above filter and unplug MAF, set aside
2) remove the braided oil line from the intake and disconnect the intake from the turbo. (its best to use a swivel 1/4 drive set or angled flathead) TAPE OFF THE TURBO INLET!!!
3) optional, but helps with knuckles loosen up t-bolt clamp holding rubber expansion tube to turbo and turn out of way.
4) remove vacuum line with small pliers, then remove bottom 10mm bolt (i think its 10mm) then one toward front, then top one. The spring pressure will push the plate off. take the plastic plate and spring and seal away from engine and swap out.
5) Push the new spring into the seal using the plastic plate, the new spring is ALOT stiffer so it takes some force. I was able to do it by myself but it was kinda tough, be patient. Thread in the top screw, the forward one and finally the bottom screw.
6) Tighten down alittle more than hand tight, reconnect your vacuum line (or leave it off for a loud as BOV sound, but put it back on because its suppose to be on) and reassemble intake and enjoy!!
Old Jan 19, 2009 | 05:56 PM
  #134
SUKXOST's Avatar
Good write up^^^
In case anyone is kinda lost to where it is....it's roughly in the middle of the engine by the firewall just to the right of the intake connecting to the turbo inlet. The cover for the spring will typically be tan in color with the 3 bolts as stated above.
Old Jan 19, 2009 | 06:07 PM
  #135
batboy's Avatar
There are several photos back on page 2 (first post). I'll repost one pic.
P.S. this is not my photo
Old Jan 19, 2009 | 06:13 PM
  #136
40rty's Avatar
now thats a nice clear pic
Old Jan 19, 2009 | 06:39 PM
  #137
Rissa's Avatar
So what did you say about CEL? Because I didn't see anything about that wee lil spring causing one but maybe I missed it.
Old Jan 19, 2009 | 07:41 PM
  #138
I got a CEL because i forgot to re-connect the vacuum line to the BOV. It sounds amazing with it disconnected but it will throw a CEL and is not good for the turbo
Image of the Intake removed from turbo and BOV cover/spring/seal removed
Just a pic of where the intake would go down.
Last edited by Black08SSTC; Jan 19, 2009 at 07:42 PM. Reason: Automerged Doublepost
Old Jan 20, 2009 | 02:38 AM
  #139
FF_ace's Avatar
i havnt got a CEL and ive had mine for about a month now
Old Jan 20, 2009 | 09:48 AM
  #140
SUKXOST's Avatar
^^^ Thats nice to know but I still think you're outnumbered on people that HAVE got a CEL from this "upgrade"
Old Jan 20, 2009 | 09:51 AM
  #141
ericgt79's Avatar
so are you putting it in or not brandon cus if you dont then im not cus im not fucken up my car
Old Jan 20, 2009 | 10:02 AM
  #142
SUKXOST's Avatar
I'll likely put it in but I want to ask a couple other people that have done it and see if they have thrown a CEL
I also want to know from someone who is well versed in tuning what thier thoughts are on these springs.
Old Jan 20, 2009 | 10:04 AM
  #143
08SStc's Avatar
hey, in regards to the CEL. i have HAHN ppc, catback and charge pipes ((soon to have intake, and intercooler 2days ))) but with those 3 mods i have no CEL on my car with well over 1000miles on the spring.
Old Jan 20, 2009 | 10:08 AM
  #144
SUKXOST's Avatar
I appreciate the info. Did you disconnect your battery and/or your PCM when you did the spring install? Also what are your quick honest thoughts on the spring? Comsidering you are "tuned" did you notice it helping? Spool faster? Louder? etc
Old Jan 20, 2009 | 10:21 AM
  #145
FF_ace's Avatar
i didnt have to disconnect the battery/pcm. my mods are pyskotuned, IC, IC piping, 3in downpipe/catback, CAI. with the upgraded spring i did see the turbo spool faster and with my CAI it makes it sound better to.
Old Jan 20, 2009 | 10:22 AM
  #146
SUKXOST's Avatar
Interesting. I think I'm gonna put mine in today :P
Old Jan 20, 2009 | 10:30 AM
  #147
08SStc's Avatar
the BOV is def louder, much crisper. the turbo spooled pretty damn fast already. considering i didnt get traction in 1st till the top of second b4 the spring, its hard to tell if its making a difference there, but running out third shifting into 4th does seem much more consistent day to day. so yes, id say it holds boost better there.
and no, i didnt disconnect the battery.
Old Jan 20, 2009 | 11:02 AM
  #148
SUKXOST's Avatar
Mine is already so loud with the CAI...I can only imagine
Old Jan 20, 2009 | 11:04 AM
  #149
its definetly worth it, im surprised with your mods that you arent loosing boost pressure do to the loose spring. Youll be amazed at how stiff the new one is compared to the older one
Old Jan 20, 2009 | 11:06 AM
  #150
SUKXOST's Avatar
As Roscoe P. Coltrane would say: Good news good news! HA
