BOV spring upgrade
I knew it was pretty simpe. I didn't put any sealant back on the bolts though as I didnt have any. Don't think it should be an issue. I don't even know why people kept sayint to take that hose off.....kinda pointless. I just left it attached. The pressure released when I took it out and pulled off the black seal on the inside holding the spring in. I can't really test it out as I've got a couple things I'm workin on but I'll get to check it out soon enough.
a thicker spring or aftermarket valve will not make your turbo spool faster, a TBE or smaller turbo will.
As long as your cool with knowing this is a SOUND MOD ONLY, unless you plan to run a turbo that boosts north of 40psi,
on the other hand if your looking for performance, spend it on intercooler, DP, Tune, etc.
also when ^^ said unless you plan to run a turbo that runs 40 psi i don't think he remembered that to boost that he'd need a bigger turbo.... you obviously wouldn't need this for a bigger turbo lol
It wasnt meant that way.* I was simply telling 2 seperate people that they could find an answer in the last few pages.
Anyway I'll probably wait for the stage kit to up the boost before I change the spring out.
