Cam phaser question
This isnt the first time I have seen this. 1 tooth off can cause all sorts or codes to pop up. I know that the pressed on wheel on the cams has caused this in at least 2 cars. ZZP took theirs back and welded the wheel.
ZZP told me to tell teh dealership check the reluctor ring on the cams they said they "did" but we all know how some dealerships work. They cant figure it out at all and now im being told maybe open a case with cosume affairs and have them buy the car back if at all possible. Im gonna go pick it up send pictures of the reluctor rings on the cams to ZZP see what they say then figure it out from there. Also I remembered my car threw a p0016 code before and thats the correlation one but it went away like a hour after it popped up so im gonna check the reluctor rings and just go from there
Any update? Figured it out? Mines still sitting in the garage broken , I just had a new exhaust cam put in so I'm going to try the ZZP intake cam and maybe replace my upper O2 sensor to try and fix it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
