cheapest axleback for sound?
Old May 16, 2009 | 02:34 PM
cresintern's Avatar
Just wonderin, are the ss/tc compatible for just an axelback or muffler replacement? I just want some growl and nothin else. Don't want catback cuz our flow is already good. Any suggestions and how much it would cost?
Old May 16, 2009 | 02:51 PM
Mazdaboi318's Avatar
I think you should just get a muffler delete if you want a growl....
Old May 16, 2009 | 02:53 PM
cmiller8006's Avatar
Go with a muffler delete for sure. Less then 100 bucks.
Old May 16, 2009 | 07:18 PM
cresintern's Avatar
what is.a muffler delete and how is it done and who does it? Will it fail me with inspection
Old May 16, 2009 | 07:40 PM
it is where you have muffler cut out and a straight pipe put in, your local exhaust shop can do it and it will pass emissions testing.
Old May 16, 2009 | 07:43 PM
PimpLay2's Avatar
just cut off muffler
cresintern's Avatar
Is there an axel back or muffler for the balt ss/tc though??!!
Old May 16, 2009 | 07:48 PM
PimpLay2's Avatar
no1 makes an axle back... and yes you can put on any muffler lol
Old May 16, 2009 | 07:59 PM
fshizl's Avatar
i would recommend a muffler delete, cause, its probably like 50-100 bucks and looks stock
if you do a muffler, youll pay for muffler and then the same 50-100 bucks to have it installed and yet almost sound like stock... lol
Old May 16, 2009 | 08:07 PM
cresintern's Avatar
No1 axelback? What's the website how much? And with mufflers I can put any muffler on? Would it be bolt on with axel back and the muffler? Any suggestions for mufflers?
Old May 16, 2009 | 08:10 PM
PimpLay2's Avatar
any website.... magnaflow...borla...flowmaster...slp...meghan racing...greddy... you pick the muffler.... yes it will bolt on if you cut the muffler on you just have to make sure the inlet is 2.5
i have magnaflow's best "street muffler" .. look on their site i dont remember the part number
Old May 16, 2009 | 10:27 PM
cresintern's Avatar
U have to cut off stock muffler and weld new one on or does stock muffler unbolt and u rebolt a new one on? I"m thinkin there is some welding goin on here?
Old May 16, 2009 | 10:50 PM
scott allen's Avatar
here check this out,best bang for the buck.
http://www.mandrelexhaustsystems.com...EXHAUST/Detail
Old May 16, 2009 | 10:57 PM
boosted4dr's Avatar
That would be dumb to do that exhaust in your link. The factory exhaust is already 2.5" and is alreayd mandrel bent, but using much better materials then aluminized steel.
If all you want is a muffler...Just go to an exhaust shop, tell them you want a new muffler (pick the type you want) They will install it for you. Just try to find one that you like the sound on (which is going to be hard to figure out just taking a guess)
Yes that does require welding, and they will have to remove some of your piping...Your looking at around 100.00 depending on what they charge for the muffler.
Old May 16, 2009 | 10:58 PM
i think the flow masters sound good
Old May 17, 2009 | 12:10 AM
hallss's Avatar
what series flowmaster are you using...i have heard 40 & 50 series on four bangers that sound like hell
Old May 17, 2009 | 12:38 PM
cresintern's Avatar
Ok I need a suggestion for an axel back or muffler. What sounds good part number and price would help
Are u sure we have a 2.5"inlet size?
Last edited by cresintern; May 17, 2009 at 12:38 PM. Reason: Automerged Doublepost
Old May 17, 2009 | 03:56 PM
09WhiteSS's Avatar
wow dude...just wow...you've asked like 4 times if anyone makes an axle back exhaust...the answer is NO!!! cut the stock muffler off, get a new one welded in place of it holy **** how hard is that to grasp?! if you want growl, like everyone else has been saying cut the stock muffler off, and get a straight pipe welded in place of it...problem solved, emissions will be fine and you'll have the growl you're looking for....
and yes, its a 2.5" inlet bc the exhaust is 2.5"
/thread
Old May 17, 2009 | 05:17 PM
gos2difbeat's Avatar
here you go im sure this will help.
go to overthetopperformance.com click cobalt. click exhaust. click cat-back. scroll down and you will see there OVER THE AXLE MUFFLER AND TIP REPLACMENT SYSTEMS. Also 09whiteSS maybe you should research before you act like a dick to th OP. Also yes our exhaust is 2.5" however when it goes over the rear axle it cuts down to 2.25".
Old May 18, 2009 | 10:09 AM
Terminator2's Avatar
Wrong, it is 2.5 all the way from the resonator to the muffler. It is not crush bent. I have my stock catback in the back of my truck right now and am looking right at it. The stock DP is 3" and the first 4-5" of the stock Catback is 3" it necks down to 2.5" right at the resonator.
Old May 18, 2009 | 10:18 AM
Staged07SS's Avatar
Administrator
Administrator
The SS/SC's catback necks down to 2.25" over the axel, but the SS/TC's catback stays 2.50" all the way back ....
Old May 18, 2009 | 06:28 PM
Mike09SS's Avatar
You suck
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
