cmiller8006 Winter build
Old Dec 22, 2010 | 01:59 AM
  #51
D1sclaimer's Avatar
Originally Posted by 06_SIC_SS
looks like a clean bay u have there my friend.. what kind of numbers does she make.. runnin to 9k
Right now, its 579whp @ 9050rpms. Getting retuned in March and gunning for 700whp stock longblock. I had a wastegate issue that I fixed and it spools really quick now. I'm also adding on an M&W CDI ignition. Heres our little dyno queen chart.
S2000 Forums -> The New Power Chart : S2KI
Originally Posted by BlackCobalt707
yours???
Yes.
Old Dec 22, 2010 | 02:02 AM
  #52
D1sclaimer's Avatar
Going through the bottom
Don't forget to unhook the steering column like Brad and I forgot to do. We kept trying to lower the subframe and were dumbfounded lol.
Old Dec 22, 2010 | 02:04 AM
  #53
06_SIC_SS's Avatar
very stout.. down right impressive. well done
Old Dec 22, 2010 | 03:48 AM
  #54
ralliartist's Avatar
On 91, I only wanted wastegate pressure which was 12psi. That put down 395whp. On E85, I put down 579.9whp @ 9050rpm and 356wtq @ 8350rpm at 20psi. We detuned it to 549whp afterwards for a more conservative tune.
There's what TJ put down in the S2k.
Old Dec 22, 2010 | 04:48 AM
  #55
black67's Avatar
This looks very interesting and fun. Going to have to make it to Norwalk sometime in the spring when you are going to be running. Might have to run down to Mansfield also, as that is not that far from me either.
So we have someone in the area that works on manual transmissions other than Sheppard?? I have been past their place, just never stopped to talk to them.
Old Dec 22, 2010 | 07:06 AM
  #56
paintballerr78's Avatar
Old Dec 22, 2010 | 07:47 AM
  #57
bykryder83's Avatar
Cmiller welcome to the precision club! Good luck with ur build, and enjoy ur car for the most part. U will not be disappointed with that turbo. Good choice dude.
Old Dec 22, 2010 | 09:59 AM
  #58
beast10007's Avatar
good luck cmiller I hope it all works out......cant wait to see this sometime next year
Old Dec 22, 2010 | 10:04 AM
  #59
BYT*SS*TURBO's Avatar
That steering knuckle piece is a real PITA to get off too!
Old Dec 22, 2010 | 10:18 AM
  #60
cmiller8006's Avatar
Well the tranny was out to do the clutch 5000 miles ago so all bolts shouldn't be to bad. I hope lol. The damn garage door guy doesn't come till 4 so I might not get it out tonight.
Old Dec 22, 2010 | 10:25 AM
  #61
beast10007's Avatar
damn.....y dont you fix the door urself, at lest close the door so you can work, and damn ant it cold
Old Dec 22, 2010 | 10:27 AM
  #62
When you take that bolt out of that linkage piece, use something to spread it slightly (dont go crazy). If you have someone to do that while you press down on the subframe, it splits pretty easily.
Old Dec 22, 2010 | 10:30 AM
  #63
Yea its cold lol. The door is closed already but it needs a new motor.
Ok thanks. I will have a buddie here so that will help with everything. He is a GM tech so i am sure he has prolly done it before.
Last edited by cmiller8006; Dec 22, 2010 at 10:30 AM. Reason: Automerged Doublepost
Old Dec 22, 2010 | 10:40 AM
  #64
beast10007's Avatar
[QUOTE=cmiller8006;5451174]Yea its cold lol. The door is closed already but it needs a new motor.
I just bought a heater for my garage from menards for ~$125 its great lastnight I changed an O2 on an eclipse in a t-shirt.
btw cant wait for vids! when do you think you guys will start tunning?
Old Dec 22, 2010 | 10:43 AM
  #65
Really I wont tune it till spring. I am on winter break and figured it was better now to just get the hard stuff done, then the car will go back to storage. I have a wood burner so it gets like 70 in the garage if I want it.
Old Dec 22, 2010 | 10:51 AM
  #66
We run a Kero Torch Heater thing, 20-30 mins and its warm enough to wear sweats and a long sleeve shirt comfortably. Spring time Im def moving to a bigger REAL shop LOL..
Old Dec 22, 2010 | 10:56 AM
  #67
See that would be sweet to only have to wait 30 minutes. It takes a couple 2-3 hours to get the garage heated with the wood burner.
Old Dec 22, 2010 | 10:58 AM
  #68
Is it insulated? Before I insulated mine it would take a couple hrs.
The torch blows it around tho, which helps. The wood stove radiates heat, you dont have a blower setup on it do you? That would help!
Old Dec 22, 2010 | 11:08 AM
  #69
It is insulated but we only have a fan we use which works but not like a blower.
Old Dec 22, 2010 | 11:14 AM
  #70
beast10007's Avatar
yea Mine heats my 2 car garage up in 20-30mins thats crazy I would keep wood in that stove all the time.....I am in winter break as well I am doing rear breaks in the next few days.
BYT a shop is a must for what you do! you could buy/build your own pole barn for around 5,000 that can fit 3 cars and an office then buy a lift from napa for 1400 and you r set! buy freinds just started a shop doing that.
Strictly Import Motorsports - Import Performance Parts and Services
Old Dec 22, 2010 | 11:21 AM
  #71
I have a oversize 2 car garage now, like really oversized lol. But I own a LOT of toys, quads, karts, bikes etc.. So once you have all that with the tools and stuff mixed in, it gets cramped with 2 people working in there. That and I want to buy my own dyno in the spring, def will need a shop for that. My neighbors already hate me :P lol.
Old Dec 22, 2010 | 11:24 AM
  #72
beast10007's Avatar
yea o well they can move...good luck with everything next year, I think a dyno would really help you start a shop. once again good luck!
Old Dec 22, 2010 | 11:46 AM
  #73
Thanks
Sorry for the OT Chris
Old Dec 22, 2010 | 11:54 AM
  #74
i dont mind.
Old Dec 22, 2010 | 06:37 PM
  #75
So are you gonna be gettin rid of ur zzp s252 then? or is it gone already
