Cobalt SS: Project 25G
Old May 27, 2013 | 01:51 AM
  #101
c130aviator's Avatar
how much of a leak are you seeing? a few psi or half your boost?
Old May 27, 2013 | 12:12 PM
  #102
Fastgti69's Avatar
I'm guessing it's a huge leak, I'm not even hitting full boost. 19 psi compared to 24. The turbo is overspinning trying to keep up with it. I'm not doing anymore WOTs until I get this fixed. I'm not trying to blow this turbo before I even actually use it.
Old May 27, 2013 | 01:53 PM
  #103
donkeyballs's Avatar
Originally Posted by Fastgti69
Yea, that was my first place I checked lol. I need to just take the lower charge pipe and silicone all sensors etc. I'm sick of it.
I siliconed mine and it fixed the leak I had.
Old May 28, 2013 | 02:40 AM
  #104
Fastgti69's Avatar
Thanks for that brotha. I'm hoping it will help, and that solves the issue.
Old May 28, 2013 | 12:44 PM
  #105
5 psi isnt that bad. I was boosting like 9 psi vs 22 psi when I had a crack in my manifold.
Old May 28, 2013 | 02:11 PM
  #106
Fastgti69's Avatar
Yea, but it's not hitting 19 @4k rpm and holding it through the redline. It gradually builds from there at like 12 psi to 19 at redline. I'm sure the turbo is being overspun like a son of a bitch lol.
Old May 30, 2013 | 01:38 PM
  #107
ATLsilverSS's Avatar
My 25g shipped today
Any advice as to run a .55 or .73 turbine housing??? 25g comp / td05 turbine...looking for ~450 on 93 and 500+ on e85
Old May 30, 2013 | 10:51 PM
  #108
Fastgti69's Avatar
Go big or go home!
Old May 30, 2013 | 11:01 PM
  #109
Yeah. Im gonna go with the .73
Old May 30, 2013 | 11:45 PM
  #110
if it shipped today why are you asking which turbine housing to go with? who did you buy it through?
Old May 31, 2013 | 12:35 AM
  #111
Because i bought it without a turbine housing
Old May 31, 2013 | 01:23 AM
  #112
your spool will suffer with a large AR, go with the smaller one for 4cyl cars.
Old May 31, 2013 | 02:39 AM
  #113
Fastgti69's Avatar
Praying that my car gets fixed this Saturday. I've been saying this 4 weeks in a row. I'm fed up with it.
Old May 31, 2013 | 12:14 PM
  #114
alerosaint's Avatar
fingers crossed bro
do you have valvesprings? If not you def going to need them to get the most out your power band.
Old May 31, 2013 | 12:35 PM
  #115
Terminator2's Avatar
.55 will spool about 500 RPMs sooner vs the .73 on your car more than likely.
Old May 31, 2013 | 02:14 PM
  #116
But will it die up top? Some graphs i have seen look almost k04 like with huge tq and hp starts to level, but does not drop, till 7000-7500. Now every graph i have seen has been on a housing at least .73 and some with even the larger td06 turbine wheel.
So im thinking that the .73 will give me 20-25psi by 4200 and be better up top till 7k. Im ok with some lag. Not too much lol but some is ok.
Old May 31, 2013 | 04:35 PM
  #117
Closer to 4600 more than likely.
Old May 31, 2013 | 06:35 PM
  #118
You could try hooking a mbc up instead of the factory boost solenoid and see if it boosts properly if the wg turns out not to be the issue.
Old May 31, 2013 | 06:53 PM
  #119
Fastgti69's Avatar
Well for now, I'm not even going to try the wastegate anymore as it's the tightest it can be and i'm still not boosting properly. I did a boost leak test and have a leak. We can hear it, we put smoke through it no smoke. We can't find it. I'm just going to have them take the whole lower charge pipe out and fully seal MAP/MAF sensor and the other bung for the boost line.
Old May 31, 2013 | 07:05 PM
  #120
Soapy water on every joint and sensor seal area will show it better than smoke imho. Like a leaky tire.
Old May 31, 2013 | 10:38 PM
  #121
Fastgti69's Avatar
Yea, we're gonna do the soapy water test too after we silicone all sensors and make sure all clamps and hoses are fully tight on. This charge pipe **** is a pain in the ass.
Old Jun 1, 2013 | 12:35 AM
  #122
Everything i have read indicates quicker spool than that with the td06 wheel with .73 or .84 housings. Idk. I really dont think it will be that laggy. James had 30psi at 4400 on his with the td06 wheel. If compared to a precision 5557 whereas 55 is a 55mm inducer comp wheel and 57 is the 57mm exducer turbine wheel my 25g would be a 6049. So its got a pretty big comp wheel but a baby turbine wheel
Hope im right lol. Who knows. I keep reading and researching and collecting opinions over the next couple days then i will make a decision and hope for the best.
Thanks for your input tho. I do appreciate getting sone knowledgeable advice and i am listening to what you are saying.
Old Jun 1, 2013 | 12:53 AM
  #123
if you are about the power up top then go with the larger AR, just gonna come in laggy in the center and up. I have a video before I built my 20g you could see at 80-100 mile per hour would shoot out of know where but it took forever to get up there. But when it does...
Old Jun 5, 2013 | 01:48 PM
  #124
My turbo arrives today. Still debating the housing. Want to get it ordered asap tho. Cant wait to get this thing on!!
Old Jun 5, 2013 | 08:13 PM
  #125
Fastgti69's Avatar
I'm telling you man, you're gonna get your 25g working before mine. I'm gonna shoot myself.
