Code P0100
Code P0100
I am having a problem with my Car a '09 t/c with trifecta tune and a ZZP downpipe. I threw the following code P0100 & P0102 I cleared all codes and and cleaned the MAF. After I clear all the codes and drive around for about ten minutes I get nothing. I turn the car off and restart and as soon as I press the traction button it turns on the cel and I get code P0100. I am able to replicate code P0102. Is this a problem with the tune or is the MAF sensor going bad.
Im guessing you have the selectable tune and the CEL comes on when you switch tunes. If the CEL comes on when you press the comp button i would guess that its the tune. But Range Check Low and Open Circuit Check kinda sounds like it might be the MAF.
OrangeCoba
Sep 25, 2015 06:06 PM
