Code P0100
Old Aug 10, 2010 | 03:43 PM
Dougger's Avatar
Code P0100
I am having a problem with my Car a '09 t/c with trifecta tune and a ZZP downpipe. I threw the following code P0100 & P0102 I cleared all codes and and cleaned the MAF. After I clear all the codes and drive around for about ten minutes I get nothing. I turn the car off and restart and as soon as I press the traction button it turns on the cel and I get code P0100. I am able to replicate code P0102. Is this a problem with the tune or is the MAF sensor going bad.
Old Aug 10, 2010 | 04:17 PM
ShagMeyer's Avatar
Im guessing you have the selectable tune and the CEL comes on when you switch tunes. If the CEL comes on when you press the comp button i would guess that its the tune. But Range Check Low and Open Circuit Check kinda sounds like it might be the MAF.
Old Aug 10, 2010 | 04:26 PM
Terminator2's Avatar
Does the CEL come on in stock mode? Those MAF codes normally mean either the sensor or the wiring is bad.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
