Cold Air Intake
Old Aug 15, 2008 | 04:19 PM
  #76
PimpLay2's Avatar
the T/C is a 13sec car man weather you believe it or not... i am terrible at launching and still ran a 14.1
Old Aug 15, 2008 | 04:20 PM
  #77
steddy2112's Avatar
What is nuts is:
We have TM in 3rd gear...imagine a tune with just the TM taken off...
Old Aug 15, 2008 | 04:53 PM
  #78
PimpLay2's Avatar
Originally Posted by steddy2112
What is nuts is:
yes i know... i seen hptuners software showed torque management
Old Aug 16, 2008 | 02:07 AM
  #79
Zander916's Avatar
I got my drop in today and got a chance to drive some.
ABSOLUTELY noticed increased throttle response.
I'm not sure about the sound of the turbo and BOV. Perhaps a little bit. Nothing that got me all worked up. lol
I think there was an increase in power a bit. Nothing to write home about but seems like the top of 3rd goes a bit quicker. Which means I'm sure the others too but 1st and 2nd go by too fast for me to really observe closely.
Z
Old Aug 18, 2008 | 09:54 AM
  #80
TrevMo's Avatar
Originally Posted by Gettinausernamesucks
yea its definatly a personal choice. The difference in sound between a drop in K&N and a full tube is probably twice the difference in sound. I had a drop in in it from day 2 of owning it. Now that said the biggest change if your going to use a drop in is to remove the air filter outlet snorkel from under the headlamp. Its not a resonator its just a snorkle. The problem with the snorkle is it necks down to about 2 1/4 inches where it goes into the air box (big restriction) I took that off last week prior to putting on the full cai. As soon as I took that off on the first drive the boost went to about 16.5 pounds and there was in improvement in spool (it did learn back to 15.5 which I expected) but the initial gain in boost told me that the overall airflow had increased. When I put the full tube on the boost went to 18/19 or so (and yes it learned back) but that indicated a large increase in air flow over the K&N without the snorkle.
The difference in spool rate of the turbo I cannot underemphasize. The thing launches like it was shot out of a cannon now which it never did before and it hits 15.5 LBS in 1 second from the time you drop the hammer in first gear. It took about three seconds or to about 4800 RPM stock. The HP/torque total hasn't changed but the torque curve definatly has which should equate to ET regardless of the ECM tuning.
I took a look at this option this weekend and it looks like if you took off this snorkel, you would be sucking in air from the engine compartment. Even if the snorkel is slightly restrictive (which it doesn't look like it is much), it is better to have it on so you suck in cold air instead of the hot air under the hood...
Old Aug 18, 2008 | 10:04 AM
  #81
SC cobaltss15's Avatar
is there anything even out for the tc.. i am interested...
Old Aug 23, 2008 | 10:46 PM
  #82
IsItFast?'s Avatar
Originally Posted by FiscalFizz
I don't own a hand-gun either.. but I know that if I load a bullet into it, **** it, and pull the trigger, it shoots a bullet out the end of a barrel. OMG HOW DID I KNOW THAT> I DON"T EVEN OWN A GUN?
Technically speaking if you just load a bullet into a gun and pull the trigger nothing will happen. You also need the cartridge, powder, and primer before a nice "bang" happens. The bullet is just the piece of lead in front of all that. All of that combined is called a "round".
...anyway moving on.
Old Sep 12, 2008 | 04:22 PM
  #83
SSturb's Avatar
Originally Posted by IsItFast?
Very nice! Do you have part numbers so we can imitate?
And Bill Hahn said their intake should be out this month at some point..
i just ordered my parts for the CAI today should be here tomorrow or monday!!!!!
no_ss
Oct 18, 2015 11:58 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
