Crank but no start. (Expert techs only)
Old Apr 20, 2023 | 08:31 PM
Larocque44's Avatar
Crank but no start condition, gm master tech is stumped.
starts with a sniff of starter fuild for a few seconds.
Checked: fuel pressure at rail, hpfp condition, has spark,.
(New fuel lines, in tank pump)
Car was sitting for a year. Previous owner stated it wouldn't start after doing fuel lines and gave up.
Canadian car and has heavy rust. Fuse box was corroded in areas. And cranking did stop so changed it out.
Old Apr 23, 2023 | 08:17 PM
2008's Avatar
Are the fuel lines connected backwards??????
Old Apr 24, 2023 | 07:41 PM
5-Speed's Avatar
Well if it runs on some starter fluid, that means you arent getting any fuel....
So the basics, what is fuel psi at the HPFP?
Is the HPFP plugged in?
Can you hear the injectors clicking while cranking it over?
Old Apr 25, 2023 | 09:45 AM
Kolt's Avatar
After the basics: What is the fuel rail pressure reading while cranking. Are you getting matching duty cycle at the HPFP regulator you can control with a scanner
Old May 6, 2024 | 09:06 PM
soundjunky's Avatar
has the stupid engine harness ground been checked.
HERE is my recent dealing with this issue.
With my example, it too stumped GM techs;
I was given a misdiagnosis, and no solution.
SSLOW06
Jul 22, 2014 05:14 PM
drew86
Mar 26, 2012 10:28 PM
OiangeSS
Jan 25, 2011 02:56 PM
wbrevels
Jun 14, 2010 04:23 PM
fjordbosun
Nitrous Oxide
Apr 6, 2008 11:17 PM
