dejon spring upgrade question
Old May 19, 2009 | 11:36 AM
  #76
Terminator2's Avatar
Originally Posted by PimpLay2
nothing lube cant do LMAO
. That is too funny. I just fell out of my chair.
Old May 19, 2009 | 11:37 AM
  #77
PimpLay2's Avatar
lmao i am laughing out loud
you a younger or older guy?
Old May 19, 2009 | 11:38 AM
  #78
I am 24 man.
Old May 19, 2009 | 11:40 AM
  #79
PimpLay2's Avatar
figured younger... if it was any other way we would be called "immature" and other words that senior citizens can think of
Old May 19, 2009 | 11:41 AM
  #80
How old are you? I am pretty mature actually but I like to laugh and have fun still.
Old May 19, 2009 | 11:48 AM
  #81
PimpLay2's Avatar
im 19
Old May 19, 2009 | 11:57 AM
  #82
im 19
So, you just graduated high school.
Old May 19, 2009 | 12:12 PM
  #83
PimpLay2's Avatar
junior in college.... im in the Air Force
Old May 19, 2009 | 12:21 PM
  #84
Oh, Ok.
Old May 19, 2009 | 02:23 PM
  #85
reign1's Avatar
im almost 21.
in nov.
lol just had to say my .02
sorry. lol
thread jack!
Old May 19, 2009 | 03:29 PM
  #86
julius41282's Avatar
2.25 is kinda small. IIRC the inlet on the turbo is 2-3/8 or so.
I purchased two sizes to be certain of fitment.
1. 3"-2.5"
2. 2.75"-2.25"
Both are for the dejon SRI. 2.75"-2.25" fits perfect. Hope that helps.
Originally Posted by Gestapo007
FTMFW! I got my Dejon with Greddy RS put on saturday night. Sounds and looks sexy.
I have the spring upgrade in and with my greddy it sounds like im getting some compressor surge under low boost. I dont see how this is remotely possible though casue I have my greddy set to really soft, and I technically have 2 BOV's untill my Block off plate comes in. Under high boost its one solid blow off. but under 5lb's of pressure it goes psh pshhhhhhh. i dont know if thats the 2 different BOV's opening at different times though. my buddy ahs the same setup with stock spring and he doesnt have this problem. im thinking under low boost and the stiffer spring rate of the stock BPV it opens later. When i get home from work today im gonna switch back to my stock spring and see what happens. If i can find the stock spring that is. Called a local performance shop and they said that as long as its under low boost ill be fine for now. And im quoting now "Youll hear people swear up and down that it will kill your turbo but if your getting a little surge at like 3lb of boost, youll be fine. if you are getting it at 15lb's then youll have a serious problem" he told me to wait till my block off plate comes in and then see what happens.
sounds cool as **** with that little surge though lol. while im normal shifting down the highway it flutters a tiny bit and when i gun it, it screams. im gonna take a vid today
I had the spring upgrade, but I took it out when I installed the CP w/HKS BOV. I have the Hahn delete plate covering the factory BPV. I was unsure at first how to do the delete plate part. I ended up putting the gray cap/seal back in with only the delete plate. Threw a CEL P2261. Took out the gray cap/seal and just installed the delete plate. Took it for a ride and CEL still on with absolutely no boost. Only one other way left to try. Put the gray cap/seal back on with the stock BPV spring and covered it with the delete plate...same exact setup as stock except the delete plate is in place of the factory plate. Took it for a ride and CEL went away...took a few key turns but went away. BOV absolutely screams under high boost. I went through a tunnel and damn near blew my eardrum out!! I get minor surge only under low boost. Usually in reverse I get a little flutter...but it's under extremely low boost. I don't know if that's normal or not but I don't know any other way to hook it up. If anyone else knows a better way to do the setup with the delete plate. Please advise!
Last edited by julius41282; May 19, 2009 at 03:29 PM. Reason: Automerged Doublepost
Old May 19, 2009 | 04:15 PM
  #87
Gestapo007's Avatar
1. 3"-2.5"
2. 2.75"-2.25"
Sounds like you got the right idea with the delete plate. It mustjust delete that vacuum nipple coming out of the back of it. I put my stock spring back in just now and no more compressor surge under low boost, but now it sounds like I dont even have a BOV because the damn stock spring is so effin soft all the air rushes out there and bypasses the BOV for the most part. lol. my delete plate should be here end of the week so im not too worried about it, but with the stiffer spring my BOV was loud as **** and had some surge. but honestly im not even too worried about low boost surge. Even a shop that twin turbos supras, 350Z's, and everything else said that flutter under 4lb's of boost is fine and wont really hurt your turbo. its not enough pressure to **** with anything on it. my Greddy is on the softest setting too. If i loosen it anymore the tensioner comes out lol. sounds so sick though when that thing hits and then right after the initial blow off you get that little metal sounding whistle. i love that
Old Jan 27, 2011 | 03:37 PM
  #88
vahdyx's Avatar
Just installed mine and will be taking mine out
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
