e85
Old May 10, 2012 | 10:07 AM
Bluekid99's Avatar
e85
so i know this was probably asked quite a few times but im still new to the lnf...what exactly is the e85 i see a pile of people talking about?
Old May 10, 2012 | 10:08 AM
mightymouse1975's Avatar
a blend of fuel. corn gas. cheaper and is used to get more hp out of the lnf with a tune.
Old May 10, 2012 | 10:10 AM
2009CobaltLT's Avatar
powered by corn!
Old May 10, 2012 | 10:15 AM
user 72239's Avatar
E85 is 85% Ethanol and 15% gasoline.
You get more HP out of it cause it has a higher octane, around 110 octane. Although it requires more energy to keep combustion therefor requiring more fuel.
I see 27 mpg with 91, but with E85 you may see 19-20 mpg. Its cheaper though
Old May 10, 2012 | 10:16 AM
MoJoJoSSsc03's Avatar
yea so pretty much you break almost even with the usage of gas and price.. depending on where you live that is... lol..
Old May 10, 2012 | 10:17 AM
Sonicyeller's Avatar
All turbocharged cars should require E85 instead of regular gas.
Old May 10, 2012 | 10:19 AM
user 72239's Avatar
I wish it was more abudant around here, You would think eastern Colorado would have more E85 stations since we are plains but no...we dont
Old May 10, 2012 | 10:20 AM
I thought you lived in Thornton? There's like 50 E85 stations in a 100 miles radius of Denver.
Old May 10, 2012 | 10:21 AM
user 72239's Avatar
Nah I live in Aurora now, by the Airport. I just havent updated it lol
Old May 10, 2012 | 10:24 AM
theamericanautos's Avatar
You get more HP out of it cause it yields more energy, however it requires more fuel to keep the burn.
I see 27 mpg with 91, but with E85 you may see 19-20 mpg. Its cheaper though.
I could be wrong, but I believe E85 actually yields less energy than gas, which is why your mpg drops. E85 has a higher octane rating so you can have more timing without knock, compared to pump gas
Old May 10, 2012 | 10:26 AM
user 72239's Avatar
Yes, you are correct. I just couldn't think of how to word it. but its like running 110 octane, but requires more fuel to keep the burn. it also burns cooler
Old May 10, 2012 | 10:30 AM
I'm not too worried about not finding it, I have my stock GMS1 ECU as a spare and I just keep it in my car. So if know I'm screwed and I'm not going to find E85, I'll just run it almost dry and fill up with regular 91 and switch ECUs.
However, I did find out that my fuel economy is just good enough on E85 to drive from Cheyenne to Denver, goto the track, make 7 or 8 passes and drive home without having to stop for gas. I drove 269 miles on one tank and refilled it with like 12.2 gallons -- so I cut it damn close.
Old May 10, 2012 | 10:37 AM
user 72239's Avatar
Did you just buy another ECU from ZZP?
Old May 10, 2012 | 10:39 AM
Nah, bought a used one from a 2008 SS/TC from the classifieds on here.
Old May 10, 2012 | 03:01 PM
SSlobalt's Avatar
I'm the same way. I keep my gas ECM in the trunk and put it in when I can't find E85. It runs like **** for about 5 minutes, then everything is A-OK. I have HPT, so I could just flash back and forth, but I don't like carrying the laptop in my car.
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
roadrunner132
Sep 16, 2015 09:13 AM
Macgyver2484
Sep 2, 2015 05:44 PM
