Fuel Injector wires for water/meth
Old Jun 28, 2009 | 02:03 PM
hiltu's Avatar
Does anyone know where/how to access the fuel injector wires? I figured it would be easy to find the injectors and therefore the wires, but i can't. I'm planning on getting a water/meth kit that will inject based on fuel injector duty cycle. Thanks
Old Jun 28, 2009 | 05:04 PM
freakta's Avatar
arent they under the valve cover
Old Jun 28, 2009 | 05:07 PM
Stamina's Avatar
Be careful doing this, since depending on how you wire it, it will change the voltage going to the injectors and then they may not inject the correct amount of fuel that the ECU is telling them to inject.
Old Jun 28, 2009 | 05:09 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i think you would be better off with a traditional boost referenced system
Old Jun 28, 2009 | 05:51 PM
Baldturbofreak's Avatar
indeed. I also think the drivers from these injectors use 60volts.
Old Jun 28, 2009 | 05:58 PM
G85 SS's Avatar
That would me more trouble than it's worth. Just get one that goes off of a boost reference and tune as a 5th injector and you'll be straight.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
roth
Sep 26, 2015 12:16 PM
