Going even bigger on the turbo. Share your thoughts
Old Dec 24, 2012 | 03:07 PM
  #76
EXsoccer1921's Avatar
go home trucker, you're drunk.
Old Dec 24, 2012 | 03:23 PM
  #77
Steviodaddio's Avatar
Has anyone ever fabbed up a TT setup for a cobalt? It would be pretty neat to run two K04s or something even a little smaller. I know there isn't **** for room in the engine bay as it is but I've seen some top mounted turbos where the wheels are sitting outside of the hood out of a cutout.
OP, stop being a ***** and just mount this bad boy up. ^.^
Old Dec 24, 2012 | 03:30 PM
  #78
574's Avatar
574
I was talking about a little N20 haha
Old Dec 24, 2012 | 03:32 PM
  #79
ford's Avatar
Only agp turbos that are bb are actually agp turbos. Since agp is brought up, the zetas are badass turbos. You could do a zeta 3.2.
I'm actually installing a zeta 3.2 on my buddies srt4. Should I just steal it lmao?
Old Dec 24, 2012 | 03:33 PM
  #80
twins just are not necessary. the amount of work you'd have to put in to mount them up vs running a properly sized single turbo just wouldn't be worth it.
Old Dec 24, 2012 | 03:36 PM
  #81
ford's Avatar
[IMG]http://t2.gstatic.com/images?q=tbn:ANd9GcRprYaCGPbeoN1LureOxAmTXW9jg6C6d 8wwEZhcrAXIQ9phXoImOiVgxik-gw[/IG]
[IMG]http://www.themotorreport.com.au/content/image/5/9/5949_big_turbo-4b77ac168f3ae.jpg[/IG]
K04s are huge for what they are. I would have an easier time finding the room to mount twin s256et lol.
Old Dec 24, 2012 | 03:38 PM
  #82
the only way i could see doing twins. they would have to be terribly small. so small that even with both of them, peak power just wouldn't be there. one mounted on the manifold to get most of its spool from cylinders 1 and 2. and the other mounted by the tstat housing getting most of its spool from 3 and 4. compressor housings on the timing chain and trans sides respectively. with the turbine sides in the middle with a shared downpipe connected in a way to prevent the exhaust coming out and flowing directly at the other turbine housing.
and even IF you could get that to work. a single 252 or 256 will still give you a crazy power band with the peak to go with it. in a simple bolt on kit with none of the custom fab work, other than modifying something to your liking, that would come with a twin setup
Old Dec 24, 2012 | 04:43 PM
  #83
Area47's Avatar
Rent me! per hour
im not the one using a small turbo
Old Dec 24, 2012 | 05:58 PM
  #84
we're on half the engine! 62 may be small to you guys. but not us. damn truckers.
Old Dec 24, 2012 | 06:01 PM
  #85
Matt M's Avatar
Originally Posted by blrt
I will hold out for a complete build until we have solution to this problem. It would be sweet just imagine making HP revving past 7200? C-mon Matt M. make our LNFs rev past 8000 rpm..
I'm revving to 8200.
That's part of the custom ECM we are workig on.
Old Dec 24, 2012 | 06:07 PM
  #86
Matt M's Avatar
Running parallel twins on an inline motor doesn't offer any advantages. Running them in series is the only way that makes sense.
Old Dec 24, 2012 | 06:13 PM
  #87
Pleass's Avatar
3.2 zeta ftw
Old Dec 24, 2012 | 06:37 PM
  #88
raver0789's Avatar
the s262 actually comes in a .55 ar as well. Should spool much quicker than the .70 exsoccer is talking about.
BorgWarner AirWerks S262 Turbochargers - PURE Tuning Inc.
Old Dec 24, 2012 | 06:38 PM
  #89
Area47's Avatar
Rent me! per hour
twin 67/66's will make me happy
Old Dec 24, 2012 | 07:15 PM
  #90
Pleass's Avatar
I smell a hint of parish truck in here
Old Dec 24, 2012 | 07:17 PM
  #91
ford's Avatar
Need a beta tester?
Old Dec 24, 2012 | 07:32 PM
  #92
Matt M's Avatar
Originally Posted by ford
Need a beta tester?
We have some lined up, but we'll see when we get there.
Old Dec 24, 2012 | 11:22 PM
  #93
ford's Avatar
I assume you were responding to stevio. I have no intention of doing twin turbo setup.
Old Dec 25, 2012 | 12:19 AM
  #94
yes him, i know you're smarter than that.
Old Dec 25, 2012 | 12:28 AM
  #95
Fastgti69's Avatar
Eww that spool on the s262 is not pleasing. Before the S256et i was actually looking at doing a custom manifold and a EFR7670 in the first place, i could just never get a hold of one. As silverbullet stated, there will be something in the works soon
Thanks for the info everyone. I will also be looking at some suspension/tire mods to actually put this power down.
Originally Posted by 574
Every thought of say... a spooling "aid"?
yes. its called going from a 262 .70 a/r to a 259 .55 a/r lol
Well here you go. I remember someone was using this on their e36 m3 with like a gt42. Actually helped reduce spool a lot he said.
Quick spool valve:
Quick Spool Valve- The ultimate TQ producing part for your Turbocharged car
Old Dec 25, 2012 | 12:38 AM
  #96
brant's Avatar
yea i mentioned this in the thread a while back, widely used in the big turbo community.. ill be running this on my 6262
Old Dec 25, 2012 | 12:49 AM
  #97
none of us are running a divided housing though. all that does is put a space between the manifold and the turbine housing and directs the exhaust flow to one portion of the wheel vs having both parts of the manifold on the turbo. and then opens up when its time to make peak power.
kind of defeats the purpose of having a divided manifold because the whole point of one is to separate the exhaust pulses and have every combustion alternate between left and right openings so they're working with each other instead of against like on a log style. even running this on a log style the exhaust pulses are still working against eachother. i haven't heard of anyone running one of these on a T3 or T25(would be even less effective). but i can imagine them not being worth it..
just my two cents.
actually, now looking at the picture compared to yours, it doesn't redirect it. it just blocks that side of the manifold all together.
Old Dec 25, 2012 | 12:51 AM
  #98
brant's Avatar
lol u mean undivided manifold, that how it works acts as a twin scroll essentially
Old Dec 25, 2012 | 12:52 AM
  #99
brant's Avatar
my friend has a evo and using 6262 +qsv and honestly we saw a 400rpm difference in spool
Old Dec 25, 2012 | 12:55 AM
  #100
All the exhaust energy is routed through half the turbine housing
they are incorrect in saying that. on a proper divided manifold half the runners go to one side, other half to the other side. both controlled by their own wastegate. that valve, being divided like the manifold blocks one side of that manifold and would then just send it out the wastegate
