Going even bigger on the turbo. Share your thoughts
Old Dec 26, 2012 | 07:07 PM
  #151
blrt's Avatar
full boost, 31.5psi, was at about 5,700. with 12psi at about 4,600. and 18psi at about 5,000.
This was on a 262? 12psi at 46000...
Old Dec 26, 2012 | 07:09 PM
  #152
ford's Avatar
i'm not like you guys though ford, i'm not worried about spooling on the street at different mph rolls. i do my racing at the track. i spool in first and then its no problem after that.
Oh i know. If i was doing a track build it would be completely different. Really i never had intentions of modding the cobalt for anything but handling and bolt-ons. Then the mod bug bit. and here i am.
Im looking for a 81 trans am right now as well and will probably drop a LS3 or similiar in it. It might get the track duty behind an auto trans.
Old Dec 26, 2012 | 07:10 PM
  #153
EXsoccer1921's Avatar
on the .70 a/r yes.
Old Dec 26, 2012 | 07:11 PM
  #154
ford's Avatar
Originally Posted by Frogstofall
With a larger EFR or a GTX series turbo and E85, I really think you could have your cake and eat it too. It aint gonna be cheap but we know your wallet is ready to puke the cash so just get it over with so we can see the videos already!!
Have you seriously looked into the GTX 35r series turbos? If you can plot your motor setup on the compressor map of a few different ones, I bet you would be surprised. I would assume the same for the larger EFR but they are so much more difficult to come by it seems.
I love the GTX seriers and they are a serious contender for me. I would rather have a GTX over the PTE turbos (no offense to anyone that runs them, they have proven to be great). Just personal bias.
I will take this time to admit one thing i dont get though. Ive seen people push some of these turbos (not mine specifically) to retarded boost levels 40-50psi+. Don't they just become heat pumps at that point? Are they running spray bars on the IC to boost that much and not increase IAT and end up with detonation? The reason i ask is if i could run a slightly smaller turbo and run the **** out of it to like 35psi i would have better spool and power delivery and a higher peak HP. Im just not sure how people are obtaining those boost levels reliably.
Old Dec 26, 2012 | 07:12 PM
  #155
blrt's Avatar
Originally Posted by ford
If they made a decent variable vane turbo that was actually reliable that would be cool. I was narrowing down the turbo but if we can get more RPM... that changes everything.
Of course my goals keep changing now. In my head i think "if im going for 600, why not 700?" **** never stops lol.
259/.63 and 8000+ redline on E85 = +600whp add a 6spd zzp tranny...
Old Dec 26, 2012 | 07:13 PM
  #156
blrt's Avatar
on the .70 a/r yes.
What's the 259/.55ar spool at?
Old Dec 26, 2012 | 07:31 PM
  #157
Frogstofall's Avatar
While I've never seen that myself, if you're right, not only are they heat pumps but also a serious disintegration risk. Considering the rpms that a turbo efficient in the high 20s/low 30s psi is, running that much over would just be asking for it. Imagine running a (current) LNF to 10,000 rpm...
The old indy series back in the day used to run 1.6L engines, pure Toluene and turbo boost at upwards of 70psi but thats another story.
Old Dec 26, 2012 | 10:17 PM
  #158
Matt M's Avatar
Someone go build this. 2 half exhaust plates. Once the WG actuator arm extent, one EP shaft will rotate clock wise and the other will be rotate counter clock. The center will be open and you can decide how big the opening will be at the EP close position. Will this work? I am just throwing this out there.
That wouldn't do anything except cause a restriction. The quick spool valve needs to be on a twin scroll turbo and it blocks off one of the scrolls to force all of the exhaust through the other scroll.
Old Dec 26, 2012 | 10:34 PM
  #159
ford's Avatar
Will an efr 8374 fit I wonder. Just saw some testing that put its spool well ahead of some smaller turbos. My setup would change a lot going back to an iwg.
Might be some overkill jumping from 55lb/min to 79lb/min lol. The 7670 I believe is 64. I am just looking at everything though as someone tested a 3582r and efr8374 back to back and had better spool on the efr.
I kid though. That would probably never spool on a 2.1
Old Dec 26, 2012 | 10:40 PM
  #160
kdub1492's Avatar
That's a big ass turbo, I think fitment would be a "huge" problem tho...
Get it, huge! haha
Old Dec 26, 2012 | 10:47 PM
  #161
cmiller8006's Avatar
Or instead of this big turbo small at thing why not a 256 with a .84 ar or something. Give up a little down low but ring it out up top. Maybe step to a 259 tho. but if we get the 8k redline you gears don't drop out of power even if you don't spool till 5k rpms. Not going to be a 40 roll car but neither is any other 4 cylinder fwd that has 400+ whp. 50-60 roll in second gear.
Old Dec 26, 2012 | 11:10 PM
  #162
ford's Avatar
Yeah I'm just messing around. Ran across some stuff while researching and posted out of boredom. It really would be overkill.
Old Dec 26, 2012 | 11:43 PM
  #163
Gosh, even on the BNR, 27-28psi and E85, I could barely do roll races at 60mph without spinning. 3rd gear was just about pointless. I'll attribute it to loss of tire meat but still... Dang!
Old Dec 27, 2012 | 02:33 AM
  #164
no idea. just have track videos. like i said i just spool once, regular shift 1-2 which only takes *snaps finger* that long to spool back up. then nls 2-3. i don't do rolls or anything like that. but, even with that being said, its insanely faster than the 262 .70
this is with just 20psi. maybe 19 wasn't paying too much attention. just know i turned it down to what should be 20psi.
Old Dec 27, 2012 | 02:36 AM
  #165
exactly. no one is really concerned with that first spool. all thats gonna do is allow you to hook up better. and on cars with a system like an ams1000, adjust your boost to the absolute max that they will hold. once its spooled though, game over, grab gears and hold on.
Old Dec 27, 2012 | 02:38 AM
  #166
Old Dec 27, 2012 | 03:21 AM
  #167
Fastgti69's Avatar
7670 for sure. That would be ideal with reasonable spool, and probably one badass powerband.
Old Dec 27, 2012 | 01:45 PM
  #168
Nfamous60's Avatar
those are numbers i like to see Cmiller lol, not sure bout taht spool time is that to get full boost?
Old Dec 27, 2012 | 02:34 PM
  #169
Matt M's Avatar
That's a pretty worthless test. To start, they have a setup that rightfully should be easily spinning the tires on the dyno. This is the first disadvantage to the turbo that spools quicker. Next, they don't show the boost for the Precision, but then show the boost for the EFR. Then at the end when they overlay the graphs, both boosts are shown, but the new one is higher which tells me that the Precision was tested at higher boost than the EFR, although they claim that they ran more on the EFR. This claim is a red flag in itself because anyone going to this length to perform the test would make another pull with a slight boost adjustment if their turbo was in fact running at less boost than the one they are competing against. Why do I call it "Their turbo?" When I went to the Sound Performance site, the first article I saw had a picture of Precision Turbo's booth at PRI and read, "We would like to first thank Precision Turbo for allowing us to participate in their booth at this years PRI (Performance Racing Industry) trade show..." then i did a search for EFR and it returned 0 results. A search for Precision returned 66 products for sale. Looks to me like their "test" is simply an advertisement for what they sell.
Old Dec 27, 2012 | 03:33 PM
  #170
Touche
Old Dec 27, 2012 | 04:18 PM
  #171
Yeah it looks like on the last screen shot they show in the video where they are superimposing the results in white letters over the screen they are only showing the Precision Turbo results. You can clearly see that one run is right about 40psi and the other is more close to 45-50psi which resulted in the higher numbers. The problem is that this last screen shot where they are trying to brag doesn't show the results they claimed at all. BUT, if you do the math it about checks out b/c at ~35-40psi, it looks like the care made close to 1000hp on the Precision.
Old Dec 27, 2012 | 05:41 PM
  #172
ford's Avatar
I saw that but was on my phone and couldnt really see the numbers. Thanks for the feedback and breakdown.
Old Dec 27, 2012 | 08:12 PM
  #173
Fastgti69's Avatar
x2, besides the fact of advertising. Even running both turbo chargers at same PSI wont make a difference. They're not the same size turbo. The compressor maps show where their efficiency range is. The EFR should be at 35 psi or more to be in efficiency range even shown in the compressor map.
Even under the description for the EFR this is a quote:
"The 74mm Gamma-Ti turbine wheel is the optimal match for the 62.6mm inducer / 83mm exducer FMW compressor wheel and is capable of 79lb/min airflow and 45+psi
boost.
I couldn't even find a compressor map for the PT6266. I really doubt even 30 psi is in that turbos efficiency range. That thing is maxed out while the EFR is barely on a DD tune HAHA. That comparison is straight BS.
Old Dec 27, 2012 | 09:34 PM
  #174
ATLsilverSS's Avatar
And you wont find one.....Precision doesnt publish compressor maps.
Old Dec 28, 2012 | 03:48 AM
  #175
Nfamous60's Avatar
i wonder why though...
