Guess what? Its back and worst.
Old Jul 24, 2010 | 10:48 PM
  #226
efactor's Avatar
Originally Posted by JTurner.CTN
It should and I hope it works out for you. Another day after being soldered and still no issue. Put the car through about 3 pulls last night on GMS1 and Trifecta still no issues. This is definitely the fix. The only downside to mine is the dealer made me pay to get it done because it was "custom" work and GM says to only crimp the wires in the install.
that's f'd up, I got mine done for free under warranty because the mechanics dectected those same codes off their OBDII, if that wasn't the case I would have gotten screwed like you and paid for it. So far I'm on day 3 with no issues to report.
Old Jul 24, 2010 | 11:11 PM
  #227
DoMiStIc_RuSh_06's Avatar
Well guys....I'm really hoping that this fixes my issues with drivability, power loss and laggy feeling. The only thing that makes me think it isn't is because I haven't had the p2261 code and that I have only had the p0236 code once.
Old Jul 25, 2010 | 01:23 AM
  #228
JTurner.CTN's Avatar
The funny part is I did have a code.
Old Jul 25, 2010 | 04:50 PM
  #229
efactor's Avatar
wow... they just bend you over the table and raped you with that labor per hour.
Old Jul 25, 2010 | 07:36 PM
  #230
So any ideas on what to try if soldering the wires don't work...the drivability in my car is kinda crappy. First gear is laggy and will hardly spin the tires, second isn't as beastly as it used to be, third is kinda laggy as well.
Just wanna get my ducks lined up in case this doesn't work
Old Jul 25, 2010 | 08:00 PM
  #231
efactor's Avatar
here's an idea! You could run it off the road into the Atlantic Ocean and watch it sail next to Greenland. that would cure all your problems.
Old Jul 25, 2010 | 08:22 PM
  #232
Yah, but I would rather just fix it....
The other day I was doing a third gear pull and the boost gauge hit a 160ish kpa spike...first time I have ever seen it happen. Could this be a sign of something. I usually see about 120-140kpa max.
Old Jul 25, 2010 | 09:23 PM
  #233
efactor's Avatar
I don't know how else to say it, I have researhed this problem to lead to the cure from other forums besides cobalts, like the sky and the solstice forums, which they all have the same engine and transmission, just different drivetrain and body look style with GMS1 equipped. They all had the same problem and they all had said to "solder the wires". I heard the same thing from the guy in Raleigh. So, solder the wires and pray its the cure to your problem. I didn't hesistate and questioned, I just did it like "Nike".
Old Jul 25, 2010 | 10:01 PM
  #234
Well we will have to see what Tuesday brings....crossing fingers that soldering helps
Old Jul 26, 2010 | 01:31 AM
  #235
Baron7700's Avatar
My wires are soldered and it still does it.
I took my hahn intake off, so now I completely stock with GMS1 and I have not had any more issues boosting past 5 psi randomly, BUT my gears still suck. I cant spin the tires in 1st or 2nd gear, when the car used to torch them.... bringing in tommorow now that its all stock.
Old Jul 26, 2010 | 01:34 AM
  #236
Try cleaning your MAF. Check your plugs. Check for boost leaks.
Old Jul 26, 2010 | 04:23 AM
  #237
ctn2mb's Avatar
Glad my dealership that installed the kit soldered them to begin with... However JT, I did find out the reason why my idle was messed up on a cold start... wasn't a vacuum leak. It was the catalyst stuff that Vince disabled on your car. Apparently with that enabled it happens. I have it disabled as well now, and no issues anymore.
Old Jul 26, 2010 | 06:19 AM
  #238
Cleaned my maf, put new stock plugs in and did a boost leak test with 25 psi of pressure. Unless my maf has gone bad. The car kinda feels like it did when I had the dejon intake on the car.
Old Jul 26, 2010 | 09:27 AM
  #239
If the wires are soldered try wiggling them a bit and see if the car falls into limp mode when you drive it. There is also a possibility that one of the sensors has gone bad. I've seen that become an issue. Or the solenoid on top of the intake that holds the 3 hoses has gone bad as well.
Old Jul 26, 2010 | 09:38 AM
  #240
If the solenoid was bad, would it cause a code or cel? The wires aren't soldered yet....they will be tomorrow.
Old Jul 26, 2010 | 09:42 AM
  #241
I think you would know. If the car is doing it at random and your wires aren't soldered I'm going to say that is more than likely the problem. in order for me to get a code it took the car staying in limp mode for a very long time turning it off and turning it back on and still staying in limp mode for me to get a code that just went away.
Soldering fixed my problem. Still no issues. I think it will do the same with yours.
Old Jul 26, 2010 | 02:09 PM
  #242
efactor's Avatar
this is about to be a week with no issues.
Old Jul 26, 2010 | 04:38 PM
  #243
Baron7700's Avatar
whats a good way to clean the MAF.. i know its sensitive to things......
I i gotta find some new stock plugs, not sure what the specs on them are tho, and throw those in, as for the boost leak I am dropping the car off on thursday to get looked at...
Old Jul 26, 2010 | 07:25 PM
  #244
efactor's Avatar
get some of that MAF Cleaner (CSR I think) at Advance Auto Parts. Spray the entire MAF, don't let the straw at the end touch the two wires on the MAF, and let it dry itself out. I already done it once to clean the MAF from the K&N filter without issues.
Old Jul 26, 2010 | 09:06 PM
  #245
NGK 1 step colder plugs you can order them from www.modernperformance.com and gap them as instructed.
Old Jul 28, 2010 | 04:39 PM
  #246
Keep us updated because this is exactly what I'm experiencing with my car.
I forgot to update.... I had my wires soldered and it still doing the same. The cars not performing 100% like it should be and the power just isn't there. I'm re cleaning the maf sensor again but I don't think that's it. I think I have a leak eithe boost or vacuum (leaning more towards vacuum since my boost test didn't bring up anything). What's a good way to test for vacuum leaks and testing the wastegate. I have a feeling that the wastegate could be sticking because the car builds boost but the power isn't there.
Last edited by DoMiStIc_RuSh_06; Jul 28, 2010 at 04:39 PM. Reason: Automerged Doublepost
Old Jul 28, 2010 | 07:15 PM
  #247
efactor's Avatar
you probably have a cracked intercooler somewhere, its happend to one person in Raleigh, NC after he had his wires solder. so far I have no prolems, except I chipped one of my rims.
Old Jul 28, 2010 | 08:27 PM
  #248
I had a couple pin holes in the synapse but I got them welded up and I pressure tested the whole system to 25 psi, plus I tested the ic to 30psi. If anything I think I may have a vac leak.
I even had this issue with my stock ic that's why i kept switching it out to see if it was the issue and it wasn't. I even put my stock CPs back on and it did the same lol. This car ******* hates me I swear.
Last edited by DoMiStIc_RuSh_06; Jul 28, 2010 at 08:27 PM. Reason: Automerged Doublepost
Old Jul 28, 2010 | 09:24 PM
  #249
efactor's Avatar
well you can go with my suggestion and wreck the car and let the government can pay for it.
Old Jul 28, 2010 | 09:27 PM
  #250
Lol trust me.... It has crossed my mind....the only thing stopping me is that I don't want my insurance to go up lol.
