having an idle issue
Old Jan 19, 2012 | 06:51 PM
Dart_SI's Avatar
car does this randomly, but the idle will sound rough and on the RPD my afr's are hovering around 16-17. (normal is about 14.8).
only thing i can know that could possibly be the cause is that i have a CEL for my EVAP purge solenoid (which i know is bad anyway, hard to start after a fillup)
anybody have a clue as to why im having this issue?
Old Jan 19, 2012 | 06:53 PM
dayhoff35's Avatar
theres no vacuum on the rpd is there?
Old Jan 19, 2012 | 06:58 PM
Dart_SI's Avatar
nope. which is why im getting a boost gauge next month.
Old Jan 19, 2012 | 07:01 PM
Chevycobaltss3's Avatar
Purge valve one. But also cold condensation on maf .
Heat soak, ect
Last edited by Chevycobaltss3; Jan 19, 2012 at 07:01 PM. Reason: Automerged Doublepost
Red_SS/TC's Avatar
Its the Evap being bad bro. I had the same problem and it went away after I changed it.
Old Jan 19, 2012 | 07:05 PM
Jalake's Avatar
how is your spark advance at idle?
im having a similar issue
Old Jan 19, 2012 | 07:07 PM
Dart_SI's Avatar
havent looked since honestly i dont know what to look for on that. other than knock retard.
Old Jan 19, 2012 | 07:08 PM
Dart_SI's Avatar
Heat soak, ect
sounds like its possible. its been 20 degrees all week (it was 65 a few days ago tho) and i always have loads of frost on my car.
Old Jan 19, 2012 | 07:09 PM
Many things can cause the spark advance to jump at idle. Maf issue, dal issue , ect.
Old Jan 19, 2012 | 08:46 PM
Frogstofall's Avatar
It's all those 30psi spikes...
Can you post a video? I know vids don't always pick up everything but might be worth a try.
Old Jan 19, 2012 | 10:12 PM
dayhoff35's Avatar
I had an issue with my timing at idle also which made it seem like my engine was pulsing, could tell with the boost guage which is why i asked. Changed up my timing at idle and all is well now.
Old Jan 19, 2012 | 10:16 PM
Yeah I did that with frogstofalls timing before and it still did it.I tuned in lower dals and still did it. So I was like wtf and he sent.me a old file and said this works great. So I put all the **** of the old file to this one and it was fine lol .
Old Jan 20, 2012 | 12:13 AM
Dart_SI's Avatar
well unfortunently im not getting a retune till i throw on the bnr2871 in march. im pretty sure the problem is my evap purge solenoid since others have had this issue from that.
i need to buy hptuners or something soon. lol.
Old Jan 20, 2012 | 07:02 AM
Dart_SI's Avatar
Bump. Car did it again this morning. Idling at 16-17 afraid but goes normal if I tap the throttle for a few secs. After I drove to work the idle is now at 14.8 afr on average.
Maybe the cold air? Its been really cold lately.
If it was a vacuum leak I assume it would still idle like poop.
Oh yea, checked my spark advance, it was jumping from 5 to as high as 15 at idle. Now its normal (no higher than 5)
Im confused. Maybe a dirty tb?
Old Jan 20, 2012 | 10:36 AM
vahdyx's Avatar
Well not sure your altitude, but here in Colorado, it gets cold often, I don't think thats normal. My car on a cold day has an AFR around 14.8
I don't think the weather has anything to do with it, but I'm just guessing here.,
Old Jan 20, 2012 | 10:45 AM
Dart_SI's Avatar
Its probably just my Damn evap solenoid stuck open. I did more research and I saw that it can cause a crappy idle.
Old Jan 20, 2012 | 01:30 PM
lockdownlegend's Avatar
its definetly evap related...if ur having a hard time starting the car after filling with gas, then the problem is the evap vent valve located by the gas tank. had the same issue and replaced it and problem was solved. evap solenoid is cheap to so just do both and its less than 30 dollars and i can guarantee your issue will be fixed
Old Jan 20, 2012 | 01:46 PM
SSlobalt's Avatar
The evap sol being stuck open creates a vac leak, so it makes sense. I think that's a $40 part, right?
Old Jan 20, 2012 | 01:52 PM
the parts are pricey. but as i said you can get both for 30 if you take the time to search. guy on ebay sells the purge solenoid for 10 dollars shipped to your door.
and as i mentioned earlier...if its rough cranking after a fill up I can almost guarantee its the vent valve by the gas tank.
Old Jan 20, 2012 | 02:14 PM
Dart_SI's Avatar
Ill probably replace both. Thanks for the help.
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
