Just got back from the dyno
Old Mar 14, 2009 | 08:02 PM
40rty's Avatar
Originally Posted by cakeeater
yea, either torque isnt on there or it peaked below 300 and is that dotted line...
unless it's a different dyno sheet....an "official pic" will show exactly what is already shown.
CAKEEATER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
PS: I kicked a mustang yesterday, it was green.
I'm on the dyno right now looking good sooo far.
Old Mar 14, 2009 | 08:03 PM
Mazdaboi318's Avatar
Cant wait to see your dyno!!! ^^^
Old Mar 14, 2009 | 08:07 PM
40rty's Avatar
going to be posting a video as well.
Old Mar 14, 2009 | 08:10 PM
the way it looks you have the most parts...so i am expecting great numbers
Old Mar 14, 2009 | 08:36 PM
peachpuff's Avatar
Torque is probably on a different scale most likely 450 on the right side, just wait till he posts the whole sheet.
Old Mar 14, 2009 | 08:41 PM
40rty's Avatar
I'm in Hawaii though and its hot here so I know I'm sure I might be a tad lacking.
Old Mar 14, 2009 | 08:47 PM
ColeJJones's Avatar
Bannned
sick ass numbers. got any kills yet??
post this in the dyno section
Old Mar 14, 2009 | 08:49 PM
cakeeater's Avatar
low DA though
Old Mar 14, 2009 | 10:14 PM
Matt M's Avatar
Yup, that would make it scale about right. I like to keep torque and HP the same scale to show off the big-block like torque these little 2 liters are putting down. I am still amazed every time I accellerate without downshifting this car. It just moves with 330+ ft lbs at 3200 RPM if you load it.
Old Mar 16, 2009 | 02:53 AM
L.P.'s Avatar
The torque is the dotted line the scale is different on the right side which is the tq. I will have to take a full picture since the guy did not come through with the file that he sent me. Though you can see that my name on that sheet is L.P. and my screen name is the same..its my sheet...here is the vid of my car getting dynoed.
BTW this was a 4th gear dyno pull.
http://www.youtube.com/watch?v=qJKeHmthTG0
Old Mar 16, 2009 | 02:56 AM
  #36
WhiteSSBalt's Avatar
Not a Sebring
Damn, those things are torque monsters! I'm sure with an aftermarket downpipe, I/C, and I/C charge piping you'd be close to 400 wtq.
Old Mar 16, 2009 | 02:58 AM
  #37
L.P.'s Avatar
Originally Posted by WhiteSSBalt
Damn, those things are torque monsters! I'm sure with an aftermarket downpipe, I/C, and I/C charge piping you'd be close to 400tq.
Honestly I think thats enough tq for me..really enough power. The track I live near opens the 28th of this month we will see how I'll do. Thank god 1st gear is limited to 10psi or it would be horrible. I need some Drs but I need to see if money will allow for it first.
Old Mar 16, 2009 | 03:09 AM
  #38
Steven Flit's Avatar
Originally Posted by L.P.
The bottom number they stopped early and it was technically the third run on the dyno they forgot to hit the record button on the first one. The dyno operator told me the first number was a lot more accurate than the 2nd.
Thats awesome
Though your power seems to fall short relatively quick.
Do the LNFs make power on the stock cams up till 6900 rpm like the LSJs?
None-the-less, good luck keeping up with you. Your trq band even before peak is damn amazing,
Happy tire spin!
Old Mar 16, 2009 | 03:15 AM
  #39
L.P.'s Avatar
They quit making power pretty much at 5800 rpms...I believe its due though to the shorter gearing. The tq probably ends quick on these engines because of the small turbos as well.....I believe these numbers are good enough for high 12's if I can get the power to the ground we will see though...I will post up my slips.
Old Mar 16, 2009 | 03:39 AM
  #40
revhigh18's Avatar
talk when you have track times
Old Mar 16, 2009 | 03:44 AM
  #41
Oh that's right... The LNF's gearing is different.
Definitely good for 12s, so long as you get a 2.2 60' or better.
You have a set of slicks or DRs ready for the track already?
Old Mar 16, 2009 | 03:58 AM
  #42
turbo upgrade already
Old Mar 16, 2009 | 04:19 AM
  #43
blackbird's Avatar
Let's be careful not to get into the rice math. The downpipe should help flow, an intercooler may help with dyno numbers compared to the street (where higher air flow over the stock cooler may be more than adequate), and charge piping probably won't do a whole lot with the flow limitation of the turbo. The only way to tell for certain is to test, but all things considered you can't take power numbers and start adding on to it for a bunch of other modifications. There could be other limitations already coming into play like fueling, knock, etc., where adding more parts might not help much if at all. The whole powertrain works as a system and while improvements here and there can help, if something is already max'd out they may not help as much as on a less modified car.
I can't see any of the dyno pics from this computer, but my guess is there was a massive swell in torque in the lower/mid-range that falls off quite a bit due to flow limitations of the turbo. Depending on the tune, the car, tractions, etc., that can make for a very fun car or one that's not as drivable as one with similar horsepower numbers on the top end and a flatter torque curve down low. That power is still very impressive for such little changes to the car and I bet is very fun once it hooks up.
The drop is more than likely due to the turbo. Gearing may affect acceleration times moving the car but less so on a dyno. You definitely should be able to click off a 12-second pass depending on your track but you might be traction limited, especially with that much torque coming on hard. The Brembo brakes are great but it sucks for drag racing not being able to fit a smaller wheel and racing slicks over them. But even with a wide drag radial on a decent track I'd predict an upper 12 at around 110 if the curve looks like what I think it does.
Old Mar 16, 2009 | 07:19 AM
  #44
metroplex's Avatar
What do stock 08-09 SS/TC's put down on the dyno?
Old Mar 16, 2009 | 07:52 AM
  #45
steddy2112's Avatar
The LNF is geared LONGER than the LSJ
3.83 vs. 4.05 or w/e it is.
Also the power drop off is because of the turbo, end of discussion. It just runs out of breath up there.
Old Mar 16, 2009 | 10:44 AM
  #46
Terminator2's Avatar
Well I just got in from going to a dyno today my mods are as follows:
Trifecta Tune
Dejon Intake
Muffler Delete
I put down 307 WHP/ 361 WTQ.
I was very surprised to see these numbers.
Uncorrected numbers?
Old Mar 16, 2009 | 11:36 AM
  #47
revhigh18's Avatar
you or obsessed with flow limitations of our stock turbo it is not that small... if it can push mid to low 300 hp range it is not small now a ford probes turbo i cant even put my dick in the compressor inlet that has "flow limitations"...
Old Mar 16, 2009 | 12:28 PM
  #48
MARIN007's Avatar
I'm about average when it comes to stock dyno numbers, check my sig.
Old Mar 16, 2009 | 12:29 PM
  #49
marcusicp's Avatar
That must be one tiny turbo then!
Old Mar 16, 2009 | 12:46 PM
  #50
FF_ace's Avatar
hahaha lol!!!
