Leaking oil under HPFP
Old Mar 22, 2016 | 06:16 PM
ampzor350's Avatar
Originally Posted by ECaulk
I didn't replace the fuel line, I wouldn't remove it a bunch of times without replacing it though. A couple times should be ok.
I guess the connectors are like dryer gas lines. They say to replace them everytime you take them off.
Old Oct 25, 2017 | 01:51 PM
Dave8699's Avatar
so I'm bringing this topic back to life tghe question I have is that I just bought a 08 LNF which I strip down to be able to paint the block and head but the thing is before I took the HPFP off I saw oil residue around that and the camshaft plate so I ordered the oring and gasket forf the HPFP and also the gasket for the camshaft plate but I'm reading around that guys are using 3 bond RTV IS that with the gasket or just RTV
Old Oct 30, 2017 | 10:26 PM
tomj77's Avatar
what u do is, with the cam plate you remove the oring completely, fill the grove with rtv, squish it in good, then do a beed on top of that yet and put it back together. let dry. on the pump u put rtv around the gasket where the pump spring goes through it on both sides, then I believe on top of the one oring. then ur cam angle sensors both in front and back of motor, remove them, remove their oring and put rtv under them, then put oring back on and put rtv on top of them, if I remember correctly, then install. let dry, and no more oil leaks ever.
tomj77's Avatar
there is a howto somewhere
Old Oct 30, 2017 | 11:19 PM
Dave8699's Avatar
Thanks that's lots of help but do you know where I can find the how to I just want to make sure I don't screw it up
Old Oct 31, 2017 | 11:05 AM
user 72239's Avatar
use both. I used both threebond and the gasket.
Old Nov 1, 2017 | 12:31 PM
northvibe's Avatar
Ugh man. So I went to do my oil change before storing the car for the winter. There was the light oil all over the engine and oil pan. I know there was a TSB for the valve cover and HPFP, but I didn't want to have a dealer touch it. So when I pull it out in the spring, I'm assuming I'll need to do the works up top with gaskets. This was documented WAY back when it was a new issue. Is the same info still good? Like no updated new locations of leaks or new gaskets and such? I have pics. I'll pull from my phone.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
