LNF block
i kind of have to worry about them then... i am planning on that kind of power but eventually i will change the pistons and rods very soon.... with my turbo set up that im doing right now those numbers are not far at all for me but obviously i will change the internals...
Cast iron is used heavily for truck and full frame SUV blocks where weight savings aren't nearly as significant as needed to justify the cost increase.
Block is aluminum. Sleeves are cast iron.
http://en.wikipedia.org/wiki/GM_Family_II_engine#Ecotec
On that earlier note, Aluminum is a material while casting is a process.
Uhhh, yea plenty of companies make iron blocks. They resist deformation better than aluminum. The block is aluminum and so are the sleeves. I wouldn't worry about the block as you are never, ever going to be making too much power for it. The sleeves on the other hand, could have to be replaced beyond certain power levels. I really have no idea what the tolerances of the sleeves are, but I would guess the limits are under or around ~550hp. You really don't have to worry about that kind of stuff right now though. Your rods and pistons will be long gone before you have to worry about sleeves.
Last edited by buellfooll; Feb 18, 2010 at 11:04 AM. Reason: Automerged Doublepost
I have a build book that goes back to 2001 where GM threw a bunch of money at a independent engine builder to work with the Ecotec to find various breaking points. They ended the testing at 747HP and they were still on the stock block AND SLEEVES. Most of the people on this forum have no idea just how strong this little engine is.
GM's 08+ performance build book for LSJ/LNF recommends upgrading sleeves, rods and valves for builds over 400bhp and pistons for over 300bhp just an fyi.
Don't flame me for these numbers being too conservative and all that fun stuff.. I'm only conveying what's in the build specs
patooyee
Oct 1, 2015 01:07 PM
