LNF Stock Clutch - Glazed or Normal From Use?
Old Oct 2, 2012 | 09:18 PM
thedubsack85's Avatar
Originally Posted by 09CobaltSS1
True, but at the same time I really don't think they took into consideration the fact that it would need to hold 350+wtrq consistantly.
Oh wait I forgot to include a clever smilie face....
It's not uncommon to even see a high mileage LSJ ion redline or SS/SC that has been turbo/TVS/MP90 swapped or on spray with GMPPS3 on the stock LSJ clutch with no real issues! It's all in how it's driven! Cause at the same time there are people who have had a replacement clutch under warranty and then decide to take it to the 1/4 and break it in less than 1K miles then cry foul cause they cant drive properly! Ive seen it before! Anything is possible but at those power levels id be more worried about the trans holding but there are instances of them being just fine, And people going through more than one transmission!
Old Oct 2, 2012 | 10:01 PM
Dart_SI's Avatar
Originally Posted by slapbetcommissioner
I ask because i havent heard of anyone using the Gmpp upgraded clutch on an LNF
Yea im an LNF. I gambled on the gmpp and it was worth every penny. I also have a 4.05 trans
Old Oct 3, 2012 | 12:30 PM
T-Man's Avatar
Originally Posted by thedubsack85
How about driving the car properly.. Then your not abusing the clutch and making it wear prematurely... The lol's in this thread amuse me. You cant honestly think that slipping the clutch is good for it in any application! And no the same rules dont apply to the SS/TC as the SS/SC. There not the same clutch! and i dont agree with having to heat the stock Lsj clutch to get it grab properly as i think it's just driver error! there are quite a few high mileage LSJ's on the redline forums still on a factory clutch that have had many passes down the 1/4 and many auto X events as well with no glazing reported...
Not sure if any of your post was directed at me and I'm not looking to argue, so I'll say this and leave it be. The link I posted is exactly for what you're describing, drive the car properly I.E shift higher in the RPMs, get off the clutch as quickly as possible etc. Has nothing to do with heating the clutch up or anything of the sorts. It was also written by an SS/SC owner and was aimed at the SS/SC crowd but I believe it applies to the SS/TC as well due to the fact that it produces so much more torque in the lower revs, especially when tuned.
As you said, fix your driver error and the clutches in both the SS/SC and SS/TC can handle just about anything you throw at them, within reason.
Old Oct 4, 2012 | 07:41 PM
I suck, make a thread and not get on the site for a couple days. Like I said, I'm still on the stock tune and haven't did any performance mods yet. The car is still under warranty. Should I just take it to a dealer?
Originally Posted by Sox-Fan
If your pedal is somewhat squishy that's not necessarily indicative of a glazed friction surface. I'd more think you overheated the fluid in the slave and need to flush it.
Anybody else think the slave cylinder just needs flushed?
My car has been doing the same thing for like two years. Holds the torque but engages way later and feels spongy. Im subd for more info on this. Went to take off and goosed it a bit and smoked the clutch. Smelled awefull. Never felt the same since. It holds torque but engages super late in the peddle travel. I hate it. BUt utnil it starts slipping i cant justify throwing in a KY stage 3 or zzp stage 4... Not sure if it is even on its last leg because of this or just doesnt feel good..
This explains it perfect. Opinions from anybody else?
Old Oct 4, 2012 | 08:35 PM
emiller's Avatar
You have almost no shot at getting a clutch warrantied.
Old Oct 5, 2012 | 02:29 PM
my post was not directed at anyone in particular. YOu cant say the same rules apply to the SS/TC to the SS/SC as they do not have the same clutch! Gm put a stronger clutch in the SS/TC cause of more HP and TQ stock. Let alone stage one TC numbers! Drive the car properly which is not east in a high HP/TQ FWD application and you will have no issues! I had traction bar's and solid mounts and still snapped an axel at the strip in 07. YOu live and you learn cause after that i did not launch the car really hard from a dig after that!
Old Oct 5, 2012 | 08:29 PM
Yeah, I kinda figured that.
hhrfreek
Jun 4, 2016 11:25 PM
camaromanss1992
Oct 1, 2015 10:51 PM
The Rookie24
Sep 20, 2015 04:33 PM
The Rookie24
Sep 14, 2015 07:03 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
