LNF Stock turbo limit
Old Nov 11, 2010 | 01:18 PM
Wangspeed's Avatar
Originally Posted by BYT*SS*TURBO
Can you read a compressor map? You are making judgements based on what you think, you even said that yourself...
And the thread isn't asking your opinion on the ideal output of the turbo..just the max output
I based it on what I remembered from a map that was posted here.
You know as well as I do that it's pushing way more hot air when you exceed the efficiency range. Can you make power? Sure. Big IC, chemical cooling from ethanol or methanol. More timing, etc. I want mine to last more than a few laps though, and really, it's not fair to say that you can run 27 psi. There are risks involved, other than the turbo.
Old Nov 11, 2010 | 01:20 PM
BYT*SS*TURBO's Avatar
Nobody is asking the max psi, they are asking the max power the turbo is rated for.
Old Nov 11, 2010 | 01:28 PM
cardelino18's Avatar
well here its the max WHP aperantly lol
09whteSSpsssh = Highest WHP and WTQ on a BYT Tune! (Stock Turbo)(356whp/413wtq)
Wangspeed's Avatar
For the turbo, it is right there on the map. That's not what folks that are pushing the overall setup are making.
Old Nov 11, 2010 | 01:31 PM
ZZP says they made evenmore then that still. I don't believe we have found the tippy top just yet
Old Nov 11, 2010 | 01:38 PM
Matt M's Avatar
We are way past that.
Old Nov 11, 2010 | 01:44 PM
I thought you said 359 with correction and like 370s without? I can get the non corrected number too... LOL!
Old Nov 11, 2010 | 01:54 PM
Matt M's Avatar
That was weeks ago.
Old Nov 11, 2010 | 01:55 PM
LOL, I like your style LOL!! Care to share anything? (even the 359 sheet would be cool) Just curious to see how the powerband differs with E vs a Meth tune.
Old Nov 11, 2010 | 02:23 PM
cubaniche's Avatar
Originally Posted by Matt M
That was weeks ago.
Saw the FB post about the LNF cams and dyno yesterday.......whares the update?
Sorry for the thread jack.
Old Nov 11, 2010 | 02:24 PM
  #36
Wickedlsj's Avatar
I have video of it....lol. It was a little disheartening to see his car making those numbers and my car making "only" 415.
Old Nov 11, 2010 | 02:37 PM
  #37
Iam Broke's Avatar
The LNF is a different situation because the mechanical pump delivers more fuel the higher you spin the motor. However, it would still be beneficial to use meth injection if you are out of fuel system. It's just typically in the midrange when the turbo hits full boost that the pump won't keep up.
Bingo, then 4 secs later at 6800 in third the CEL pops Reduced Engine Power for low fuel rail pressure.
Old Nov 11, 2010 | 02:38 PM
  #38
Post that **** up
Old Nov 11, 2010 | 02:43 PM
  #39
09CobaltSS1's Avatar
wait a minute.. so he made more than 415whp with the stock turbo or am I reading something wrong here???
Old Nov 11, 2010 | 02:53 PM
  #40
^I got the same impression from his statement Or maybe real close to 400whp making his bigger turbo look bad? IDK.
Def wanna see tho now LOL!
Old Nov 11, 2010 | 02:56 PM
  #41
CudaJoe's Avatar
I too think this is what he meant. I want these cams, lol.
Old Nov 11, 2010 | 03:23 PM
  #42
Wickedlsj's Avatar
I was referring to the 370 uncorrected. I'm assuming with cams it's in the 400 area uncorrected, but I haven't been able to get that info out of them yet!
/speculation
Old Nov 11, 2010 | 03:46 PM
  #43
/speculation
ehh 400whp (even uncorrected) on the stock turbo is a fun thought and all, but I just really can't see that happening even with a super aggressive long duration cam and e-85. You simply won't be able to push enough air to keep up with the rpm you will need to spin to utilize that sort of an aggressive cam profile..
That being said, I would LOVE to be proven wrong. 400whp on the stock turbo (and stock fuel system!!) would be freakin fantastic..
Old Nov 11, 2010 | 04:04 PM
  #44
INFE's Avatar
I can't see 400whp happing on the stock turbo and turbo mani we are having problems making over 400whp with a 3076 swaped lnf because he's still using the stock turbo mani. You just cant get enough flow. I should add on a SAE corrected dynojet that does not put out magical numbers.
Old Nov 12, 2010 | 12:17 PM
  #45
Khase's Avatar
If Jimbo is using the ZZP LNF downpipe would that mean I can also use a aftermarket LNF catback? or is the piping routed differently.
Old Mar 30, 2011 | 07:37 PM
  #46
Khase's Avatar
^^Decided to keep the car another two years so I'm now doing parts collection. Can I use the LNF catback?
Old Mar 30, 2011 | 08:00 PM
  #47
gmtech16450yz
Guest
Posts: n/a
My stock turbo LNF put down 760whp. See how easy that was to say? Doesn't mean it's true.
The only dyno numbers I'll believe are ones I've either seen myself or done at an IMPARTIAL/OBJECTIVE dyno shop, not the one selling the parts.
Just sayin. Not accusing. Just sayin. Remember, this is the internet. I just saw somebody post a craigslist ad for an LS7 Prius. Lol. Prolly wanted the money wired to Nigeria.
Old Mar 30, 2011 | 10:59 PM
  #48
Matt M's Avatar
I know this thread is old, but I lol'd at this post since we have recently pushed to the mid 500s on the stock mani.
Old Mar 30, 2011 | 11:02 PM
  #49
Matt M's Avatar
Just hatin. Not accusing. Just hatin. Remember, this is the internet. I just saw somebody post a craigslist ad for an LS7 Prius. Lol. Prolly wanted the money wired to Nigeria.
Fixed it for you.
You can poke at us all you want. We back up all our power numbers at the track.
Old Mar 30, 2011 | 11:10 PM
  #50
JacBlackSS/TC's Avatar
nick can i can 350 on pump??? lol
Canadia
Oct 6, 2015 10:20 PM
camaromanss1992
Oct 1, 2015 10:51 PM
TylerJHowell
Sep 21, 2015 06:47 PM
jcalvin1126
Sep 11, 2015 10:24 AM
Josh@ottp
Sep 8, 2015 10:18 AM
