LNF Throttle Body Swap Testing
Old 05-18-2009, 04:21 PM
Terminator2's Avatar
Originally Posted by 1badBlueberrySC
THAT WAS NOT THE STOCK TURBO! CHeck their other thread people... this turbo runs out of breath well before 400ft/lbs
Actually it was. They took their big turbo that made 400 whp 400 wtrq. They are running a ported head on their car. Heck if my car can make 375 wrtq on the stock head. 400 wtrq is possible on 23-24 psi in the midrange. It just cannot hold the pressure much past 5k when you have the boost set that high. Shaft speed is way to fast at that point.
Old 05-18-2009, 04:22 PM
1badBlueberrySC's Avatar
I didn't see the ported head into this equation....
Old 05-18-2009, 04:23 PM
Haz l33t wheelz.
ls1fbody's Avatar
are they the first to port the LNF head?
what kind of issues does that create with the DI?
Old 05-18-2009, 04:24 PM
Read one of the other posts there is someone else who posted in this thread that claims 316 whp 396 wrtq at 23 psi on the stock head. . That is way too much torque for the stock clutch. Anything above 350 wrtq seems to make it slip some.
Old 05-18-2009, 04:31 PM
Matt M's Avatar
Originally Posted by Terminator2
You got it. Because the diameter is changed you are in effect fooling the ECM into thinking it has reached it target pressure drop when it has not. I think the bigger throttle body is tricking the ECM into thinking it has reached the point sooner so less power. IIRC it is kinda like the DALs when you mod it reaches the target airload sooner with less boost pressure needed. The air velocity is decreased compared to the stock opening because of the larger surface area an that is skewing readings. I wish I knew more. I would contact Baldturbofreak if you want to know more. He knows what happens exactly when you change the diameter of the throttle body on the LNF.
We verified that 100% actual throttle position is what it says. When the PCM closes the throttle a little (or a lot) for various reasons, it shows on the log as doing so. In this case, it maintains 100% throttle throughout the pass. We also regulated the MAP on the intake manifold, but it didn't seem to help, although HP numbers today have been about 6-8 higher than Saturday, so who knows.
The turbo cannot support 411ft/lbs...
Just ask Terminator pretty much has max'd it out... at 350whp and 375wtq
I smell somethin.......
It can and does support 411 ft lbs. If we start the pull earlier, I bet it will make a little more yet. Why are you so quick to dispute everything we say. We are in this to support the community and make these cars fast together. Stop fighting everything we do and say.
Old 05-18-2009, 04:35 PM
I guess you are finding out how tempremental the ECM on this car is. When I did my chargepipes the car ran like complete crap for the first 100 miles or so. Drive the car around for a while and see what happens. . It might see gains after it relearns some. 1badblueberrysc had 11* of KR showing with his new IC that went away after a few hundred miles. These things are so funny about mods.
He did not know you are running a ported head on the car. My car would easily be over 400 wtrq with your head on it. . Need money for the install though. I cannot do it myself unfortunately.
Old 05-18-2009, 04:37 PM
I'm not disputing what you said Matt... get your panties out of your butt. I didn't not see the ported head.
Goddamn read what I wrote dude!
Old 05-18-2009, 04:38 PM
mkriebs's Avatar
What Are We Yelling About!?!?!
Old 05-18-2009, 04:39 PM
Who's yelling?
Old 05-18-2009, 04:40 PM
mkriebs's Avatar
Lol... I just hope they can get this panned out. I would be interested to see what this would do on the big turbo balt... should be able to get a few more MAF lbs/min, which would be nice.
Old 05-18-2009, 04:59 PM
  #36
revhigh18's Avatar
i want a ported head
Old 05-18-2009, 05:00 PM
  #37
40rty's Avatar
Interesting!!!
Old 05-18-2009, 05:01 PM
  #38
steddy2112's Avatar
Then PM them or buy one.
This is a thread about throttle body swapping and how it apparently is failing.
Kudos for trying, but I think I will not go through a headache for 4-5mm...but hey, more vendors should do this.
Old 05-18-2009, 05:02 PM
  #39
revhigh18's Avatar
how hard was it to get the head off of this car
Old 05-18-2009, 05:55 PM
  #40
PimpLay2's Avatar
It is a pain.You have to remove the valvecover, cam chains, cams, manifold for the turbo, turbo itself, etc. It is a big job unless, and you are a master mechanic I would not attempt it.
that answer ure question revhigh
Old 05-18-2009, 06:08 PM
  #41
thecobaltguy's Avatar
was the ECM programmed for the different TB that could be the reason for the loss
Old 05-18-2009, 07:17 PM
  #42
Thanks Pimp.
Old 05-18-2009, 07:36 PM
  #43
Matt M's Avatar
lol. likewise.
We did another pull going WOT at 40mph in 3rd gear and torque was 420 ft lbs. Going WOT that early results in closed throttle and open bypass valve at about 90mph based on the 3 second overboost. Hopefully we won't have to regulate the MAP sensors with the stock turbo.
Old 05-18-2009, 07:41 PM
  #44
mkriebs's Avatar
Shouldn't you be dynoing in 4th gear, or the gear closest to a 1:1 ratio?
Old 05-18-2009, 07:43 PM
  #45
lol. likewise.
Back your DALs off some. The torque will drop but at least the throttle wont slam shut after 3 seconds. Gotta sacrifice some of that torque for the sake of driveability. if I pushed mine any harder it would do the same. 400+ wtrq does nothing if the throttle slams shut on you.
Old 05-18-2009, 07:49 PM
  #46
MaxVQ35DE's Avatar
I wonder if the GM upgrade will solve the overboosting issue....
Old 05-18-2009, 08:28 PM
  #47
PimpLay2's Avatar
same here... thats why ill be one of the first to get the kit on.. then just change the tune back to psykostevo's and see how it runs with the upgraded sensors
Old 05-18-2009, 08:39 PM
  #48
Mazdaboi318's Avatar
can you just buy the sensors?
Old 05-18-2009, 09:36 PM
  #49
Matt M's Avatar
We pulled the motor to put in the clutch, replace the head, and swap back to the stock turbo.
Swapping the head is a pretty solid days work if you take your time and double check everything.
We don't have DALs with the manual boost controller. We will get the boost leveled out for running this car on the street or at the track. For now, we are just pushing for higher numbers to see how everything responds.
I put the stock intake and TB back on after a few pulls today. After a few more pulls, we dyno'd again with the boost controller bumped up a little and going WOT by 30mph. Max boost was 29psi and torque hit 428 ft lbs. Here's a couple pulls starting at different RPMs to show how the boost eventually fades to the same level regardless of how the pull starts.
Old 05-19-2009, 12:21 AM
  #50
Rent me! per hour
Area47's Avatar
hows the inj ms looking? pegged 6ms yet?
Quick Reply: LNF Throttle Body Swap Testing
