LNF Valve Gunk..
Old May 19, 2014 | 03:54 PM
  #376
Terminator2's Avatar
I scoped my valves today using the brake booster line.
At 88k miles my valves look pristine. We scoped a buddy of mine's SS with 42k miles and his were worse than mine. I was suprised
Whose car is the other one?
Old May 19, 2014 | 04:00 PM
  #377
user 72239's Avatar
Ecaulks.
Gonna sandblast them anyway, watch number 2 be clean but 1, 3 and 4 be all gunked up lol
Old May 19, 2014 | 04:18 PM
  #378
Ecaulks.
I still think running them rich like when that car was trifecta tuned and tuned by James gunks them up faster (more combustion deposits and more oil blowing by as things get dirty and wear) and once dirty you have to pull the mani to clean them well. Mine were clean as could be at 34K miles when I checked them. The other factor is how well seated his rings are and oil type (brand) used.
Old May 19, 2014 | 04:24 PM
  #379
user 72239's Avatar
I had forgot it was trifecta tuned. I wonder if that does have something to do with it. I use Mobil 1 High mileage full Synthetic 5w-30.
Old May 20, 2014 | 05:31 AM
  #380
Unfortunately for the first 32k of this engine i'm not sure how it was treated or if low ash oil was used. Compression test comes back good, but I havent had a leak down done. I think driving style has a lot to do with it also, short little trips spending more time idling vs longer highway drives at 2500rpms and higher.
Old Sep 2, 2015 | 07:44 AM
  #381
GoodSpeed150's Avatar
Does anyone make a tool like they do for bmws/minis?
Could be a lot easier for cleanup.
I'm going to have to tackle this job soon. Getting bad hesitation in boost and during startup.
Old Sep 2, 2015 | 08:33 AM
  #382
Duct tape a 5/16 line to your vacuum that helps with controlling the material coming out of the runner, the tool would cost more than it's worth just cover everything
Old Sep 2, 2015 | 09:16 AM
  #383
umrdyldo's Avatar
My thought is to 3D print something to spray and vacuum at the same time. But I don't have 3D CAD experience
I'm sure someone has dimensions of the intake port on the head.
Old Sep 3, 2015 | 08:31 AM
  #384
Powell Race Parts's Avatar
^^ It doesnt really matter. By the time you spent all that time and money developing a tool you could have done a kazillion valve cleanings.
Use a lot of duct tape and towels to isolate the port and a vacuum. The blaster will fill the port up soon enough, without a vacuum and you need to do it carefully, It takes about 20 mins total per port so just over an hour. It takes another couple of hours to remove, prep and replace, along with clean up. Four hours if its a first time job. GM cleaner helps for touch up. New gasket and valve helps. Eliminating the valve and running all the blowby ports through the Mann Hummel seperator works great for me. Just costs more time and money to do it.
Old Sep 6, 2015 | 02:42 AM
  #385
wol-shiver's Avatar
Hi John,
If its a 4 hour job why are people charging 600$? Does the media cost that much?
Old Sep 6, 2015 | 10:41 AM
  #386
Labor plus materials. You have to get equipment specifically for it and you have a mess to clean up after, thats not included in John's 4h. And John has it down since he's done so many, most shops would take closer to 5-6h due to infrequent blastings.
Old Sep 7, 2015 | 03:52 PM
  #387
Originally Posted by wol-shiver
Hi John,
oil. filter. inlet manifold gasket. pcv valve. media is not a big expense at all. However, GM upper cylinder cleaner is not cheap . It is hard to get mobil 1 in canada for under 50 dollars to start with. Many times the inlet manifold is screwed up with gunk as well (especially LSJ) and that takes a lot more than an hour to do right, the air filter is dirty and needs replacing, and the throttle body needs cleaning.
service tools count for a lot and it takes a ton of clean up afterwards. Duct tape and laundry for the towels I use lol . I am not trying to justify the price, it is what it is, but as eCaulk points out, it all adds up. Tax in Canada is 13 % pretty much
Old Sep 4, 2016 | 11:59 AM
  #388
cobaltssdude420's Avatar
Maybe this will explain why i idle rough sometimes...
Old Sep 4, 2016 | 12:36 PM
  #389
Dutchman's Avatar
could be, how many Kms dude?
John I'm loving the seperator and job you did on my valves, definitely worth it for imo
Old Sep 4, 2016 | 08:46 PM
  #390
63 Nova SS's Avatar
Mine did when they were dirty. At 32,000 miles they looked bad.
Old Sep 13, 2016 | 12:32 PM
  #391
mzspd's Avatar
I have to get this done.. 135 kms on my car.. Getting the rough idle. I also am due for an oil change and have a set of new plugs.
Old Sep 13, 2016 | 12:37 PM
  #392
umrdyldo's Avatar
Great time to do it. Good luck. Take your time and tape off everything you can imagine.
Old Sep 13, 2016 | 02:45 PM
  #393
mzspd's Avatar
Is everyone just walnut blasting or does soaking it and cleaning it with picks also work?
I don't have any of the walnut blasting supplies.
Old Sep 13, 2016 | 02:51 PM
  #394
I've heard they do both things
Old Sep 13, 2016 | 03:01 PM
  #395
umrdyldo's Avatar
If you don't have the ability to walnut blast easy, then by all means get the cleaner and soak the valves overnight. I bought a set of picks and a gun cleaning kit with all kinds of brushes and pads. Worked pretty well.
Old Sep 13, 2016 | 03:45 PM
  #396
mzspd's Avatar
Sweet thanks guys, guess i will order the PCV and Intake Gasket and go to town this weekend. Also have my CABs to do as well.
  #397
hawkssoccer11's Avatar
you can get a blast kit from harbor freight for a good price man.
Old Sep 13, 2016 | 04:04 PM
  #398
mzspd's Avatar
Unfortunately we do not have harbor freight in Canada.
Is this the top end cleaner that everyone is using??
https://www.amazon.ca/Genuine-888618.../dp/B00BK7LR36
Old Sep 13, 2016 | 04:14 PM
  #399
umrdyldo's Avatar
Yes or this
https://goo.gl/owk8pM
A lot of people like both.
Don't use on open valves obviously.
Old Sep 13, 2016 | 04:17 PM
  #400
Also get a gun bore cleaning kit for the brass brushes and handles, those work great
