Looks like I need a new engine
Old Nov 24, 2016 | 12:20 PM
  #76
Stay with everything lol
Old Nov 24, 2016 | 12:26 PM
  #77
Omiotek's Avatar
I also have totally forgot but i have an lnf with 35k on it. Its a biddy of mines hes selling. I think complete hes asking 1600.
Old Nov 24, 2016 | 01:03 PM
  #78
heeter_33's Avatar
I'm ordering an LDK from Mongo this weekend no matter what. Not really wanting to sell my built head anyways. I threw up a bunch of Black Friday taillight deals hoping that I won't even have to sell my Ultraleggeras lol. And I don't think I'd be happy with a K04R since I've tasted that ZFR too many times lol
Do you sell your tails through facebook?
Old Nov 24, 2016 | 01:21 PM
  #79
He does
Old Nov 24, 2016 | 01:25 PM
  #80
tomj77's Avatar
Originally Posted by Omiotek
I personaly feel the design of the oil feed is flawed in everyway except the fact they are trying to keep it short as possible. The biggest issue i see in a lot of manufactuering is some of thebproducts for cars people heavily road race are being tested on track but rather being tested based on statistics. Now in some cases this will work. However will direct injection becoming common i honestly feel things should be tested in different scenarios. The heat generated is extreme during a session and a oil line rubbing tbe manifold wont last even with heat wrap tjat exceeds temp build ups.
When i install zfrs i give the feed back to the customer to keep as a spare. I use aeroquip teflon coated line and fittings to match. Aeroquip is hands down the best plumbing out there along with fragola as my second favorite. They do however come at a steeper price then buying chinese fittings or russell or earls.
This is my solution for the lnf and i movr the oil feed location from the rear port to the front port. The ldk would have to be slightly longer.
I think im gonna do this, i dont like the way the oil feed is either. Especially with an external dump, it touches the dump tube.
Old Nov 24, 2016 | 01:28 PM
  #81
colodude18's Avatar
Yep go to www.facebook.com/ledtaillights
Old Nov 25, 2016 | 02:20 PM
  #82
colodude18's Avatar
LDK long block has been ordered from Mongo
Old Nov 26, 2016 | 05:29 PM
  #83
colodude18's Avatar
Originally Posted by KMO43
What happened was the oil line went and after all the oil leaked out the bottom end started making so much friction the engine overheated. Now that the clamp was off the extra pressure of the overheated coolant system blew the line off.
Adrian pull the oil line off and where it looks burnt try to bend it. I bet it'll crack because its been burnt through.
Yes this is a common issue to solve it i recommend a longer oil hose. My ceramic coated pcs helped but didn't solve it for me. Also I have some heat shielding I use that I can post a pic later that works very well and is cheap.
Finally got around to pulling off the oil line. There was no visual damage on the outside but I could bend it very easily in one spot close to the turbo. See picture below. Compared to how hard it is to bend the hose in other spots, my guess is this is where the hose inside the braid failed. I imagine with full oil pressure oil would squirt out quite freely through the braided hose.
Old Nov 26, 2016 | 05:38 PM
  #84
KMO43's Avatar
Put ur finger over the end and blow in it
Old Nov 26, 2016 | 06:01 PM
  #85
colodude18's Avatar
I did you one better and dremeled off the braid. Hose was totally cooked and pulverized in the middle. I think this is definitely a design flaw. Anyone?
Old Nov 26, 2016 | 06:13 PM
  #86
Devin86's Avatar
Yeah looks like what happens to all the stock wire protectors in our cars. To much heat and it crumbled.
Old Nov 26, 2016 | 07:13 PM
  #87
Wow that's crazy
Old Nov 26, 2016 | 07:51 PM
  #88
colodude18's Avatar
I recommend that everyone with a ZFR consider replacing their turbo oil feed lines with something better like Omiotek has described. This hose will end up costing me 3 grand minimum
Old Nov 26, 2016 | 08:25 PM
  #89
63 Nova SS's Avatar
Nice job of dissecting it. That's crazy and I will bet it's due to heat. Thanks for helping all of us out Adrian. Sorry about the motor.
Old Nov 26, 2016 | 08:28 PM
  #90
Do you really think it's necessary for people that don't go to the track and stuff?
Old Nov 26, 2016 | 08:37 PM
  #91
Def look into DEI's cool tube at least, you need to keep the heat away from that line. It's certainly work a look (given your car is down right now)
Old Nov 26, 2016 | 08:42 PM
  #92
Well my car isn't down yet since most parts haven't arrived
Old Nov 26, 2016 | 08:45 PM
  #93
colodude18's Avatar
I really don't know, but for what, 50 bucks, do you really want to gamble your engine? Just sayin' ��
Old Nov 26, 2016 | 08:53 PM
  #94
KMO43's Avatar
Yes it sure is
Old Nov 26, 2016 | 08:54 PM
  #95
Haha well my engine isn't build and it has 100k so I wouldnt be to sad. But your right where could we get one tho?
Old Nov 26, 2016 | 09:01 PM
  #96
When it's down (which I assume is soon) check it out. You don't daily it do you?
Old Nov 26, 2016 | 09:12 PM
  #97
colodude18's Avatar
https://www.designengineering.com/ca...l-tube-extreme
Old Nov 26, 2016 | 09:18 PM
  #98
Amazon sells them too
Old Nov 26, 2016 | 09:20 PM
  #99
Nah I don't daily the car right now but at some point I might start to. Well that's not bad to be honest so it just changing the wrap to not let it heat up. For some reason I was thinking of having to change the pipe
Old Nov 26, 2016 | 09:21 PM
  #100
Devin86's Avatar
I'm definitely gonna pick some up it gets 110°F+ during the summer months here.
